BikeBanditTrident-Exhausts.comAdvanstarMotorcycleShows
Old 10-26-2004   #1 (permalink)
Anyone had this? '00 RS.
I was riding yesterday and the transmission jumped out of gear when I was in 6th. I think I had upshifted a few minutes before and I may not have been as firm on the shift as I should have been.
Odd though.
I was just wondering if this is a pointer to some kind of trouble or if its just "one of those things".
Old 10-26-2004   #2 (permalink)
Favorite Bike: 2003 Sprint ST
never happend to me...
how did you noticed it?
SpiderTex is offline   Reply With Quote
Old 10-26-2004   #3 (permalink)
Favorite Bike: 2002 Sprint ST
Try adjusting your linkage so the shifter is down more. 1/4 " or so should do it.
Don
Old 10-26-2004   #4 (permalink)
That has only happened to me a couple of times when I had done clutchless shifts. More common is the periodic false neutral from 4th to 5th or 5th to 6th.
1fastcat is offline   Reply With Quote
Old 10-26-2004   #5 (permalink)
I'll try the linkage thing. Its probably due to me giving only a short tug on the clutch while shifting. And doing only a quick shift at that. I'll check the position of the shift lever as well and just try to be more careful.
I was mainly worried that if no-one had exerienced this, it might be the start of trouble.
Old 10-26-2004   #6 (permalink)
I've had the false neutral between 5th and 6th but it has never fallen out of gear. I suspect you didn't "plant" it into 6th.
Devo is offline   Reply With Quote
Old 10-26-2004   #7 (permalink)
Mine also has a false neutral between 5th and 6th, but never has jumped back out of 6th.
jeff tarlton
jefftarlton is offline   Reply With Quote
When to shift into 5th and 6th gear on Trophy VTXED Trophy 6 10-26-2007 11:11 PM
5th and 6th misses are really getting to be aggravating 4N099 Sprint Forum 26 09-30-2007 10:27 AM
Neutral between 6th and 5th gear - twice in two days, and a very close call.. Max_NYC Speed Triple Forum 9 08-07-2007 03:25 PM
Miss Shift between 5th & 6th Blockhead Tiger Workshop 5 08-07-2006 06:25 AM
slipping between 5th and 6th gears punisher Triumph SuperSports 5 07-14-2004 04:33 PM
