Sprint RS digital Speedo not working - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 06-17-2007, 01:31 AM   #1 (permalink)
JRSPRINTRS
The Speedo on my 2004 Sprint RS just stopped working on this morning's ride. Anybody else run across this problem? :???:
Old 06-17-2007, 02:28 AM   #2 (permalink)
DEcosse's Avatar
Is the display out (1) or stuck at zero (2)?
If (1) this is a symptom when battery volts are low. Check your battery & your charging system.
If (2) then you have a problem with the wheel speed sender. Have you had front wheel off recently? Usually a symptom of incorrect re-installation & the drive magnet ends up getting broken.
Unfortunately you cannot get just the magnet as a stand-alone piece - have to buy the whole drive.
T'Rat.net BOTM November 2009
Old 06-17-2007, 02:44 PM   #3 (permalink)
JRSPRINTRS
Many thanks. It's No. 2, and yes front wheel was off for new tire. Mechanic that did it is a good friend and a great guy, but I've long known his attention to detail leaves something to be desired. Will check it out and proceed accordingly.
JR
Old 06-18-2007, 06:35 PM   #4 (permalink)
My speedo was stuck at 0 as well, but mine was a voltage issue. A quick way to check it is to not give the computer time to get through its diagnostic before starting the bike. Turn the key on and immediately hit the starter. It will 'trick' the bike in to thinking there's enough juice to run the speedo.
It's easy experiment, so give it a try before taking the wheel off or anything crazy like that....
JayMoney is offline   Reply With Quote
2007 Tiger digital speedo markhewins Tiger Workshop (archive) 1 03-21-2007 06:53 PM
Digital Drive Speedo Retro for pre-02 models DEcosse Speed Triple Forum 8 01-30-2007 12:23 AM
Digital Drive Speedo Upgrade for pre-O2 DEcosse Daytona Deliberations 4 09-30-2006 12:39 PM
Speedo working less and less jellero Sprint Forum 6 08-09-2005 03:48 AM
speedo quit working... dml955i Speed Triple Forum 6 10-08-2004 01:44 PM
