thanks for the help. I got the heated hand grip kit from aerostitch and it is designed very poorly. I couldnt figure out the which wire to connect it to so i just went to the fuse box as a temporary solution. When i turned the heat on the resistor used for the low setting got so hot it started melting stuff. Does anyone know of a different kit that is designed better. thanks for all your help.
