Another owner's manual oversight. As you guessed, you can adjust the throttle cable at the grip end adjuster.
1. Set the opening cable so that it has an equal amount of adjustment in both directions.
2. Then adjust it to give 2-3mm of play at the twist grip.
3. With the throttle fully closed, check that the closing cable has 2-3mm freeplay. Adjust as necessary.
4. Make sure you have retightened the locknuts.
The 2-3mm freeplay is the factory recommended setting.
Oldndumb
Caveat lector
