Stiff throttle? 2000 st vs. friends 2001 speed triple - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-14-2007, 06:37 PM   #1 (permalink)
I was talking to a friend with a speed triple and asked if his throttle seemed stiff
he said give it a try
I could easily twist his throttle with the end of one pinky where as my throttle will actually make my wrist sore after a long ride
is it normal to be that stiff or do I need to do an inspection and lube job
If you feel froggy boy then go ahead and jump
stwanted is offline   Reply With Quote
Old 06-14-2007, 07:07 PM   #2 (permalink)
Favourite Bike: '03 Sprint RS
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Extra Motorcycle: CB400SF, 4 x DT175, MX80
The easiest way is to try to get some thin machine oil down the end and let it drain through.
The proper way is to remove it, clean it with petrol, drip oil down the tube then replace the cable.
Either way it needs a lube.. :-D
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 05:31 AM
Why is my throttle so stiff????? Thefallenone Sprint Forum 18 09-30-2008 10:34 AM
speed triple 2001 w/Daytona 2001 enigine Martin_st Maintenance & Workshop Talk 4 12-22-2007 02:39 PM
stiff throttle IAN79 Daytona Deliberations 4 12-12-2007 07:53 PM
2001 Speed Triple triplepunk Speed Triple Forum 4 07-29-2005 09:53 PM
