RacerPartsWholesaleAnnitori DistributingbritishcustomsTrident-Exhausts.comShopTriumph.comSpringfield ArmoryTriumphPerformanceUSASportbikeTrackGearBikeBandit
RacerPartsWholesale
Old 06-10-2007   #1 (permalink)
PeirreOBollox's Avatar
can anyone tell me what the 2 unused multi plugs are for which are behind the cylinders, I saw them yesturday when I took off the tank, 1 is a 2 pin white plug the other is a grey multi plug :???: :???:
I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter.
PeirreOBollox is offline   Reply With Quote
Old 06-10-2007   #2 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
Can you supply the wire colors? Is your bike ABS?
Oldndumb
Caveat lector
Old 06-10-2007   #3 (permalink)
I don`t have the wire colours, and its a non abs bike
I uspect 1 of em is for the californian market
Old 06-10-2007   #4 (permalink)
oldndumb's Avatar
Sorry, I don't have the expertise to help without the colors. Just guessing at possibilities: ABS/Alarm/Canister Purge (Cal only)/SatNav. The ABS has 2 each 2 pin connectors for each wheel. The purge valve has one 2 pin connector. The alarm connector has 12 pins. The SatNav has 2 pins.
Hopefully, somebody might remember or have pics.
Oldndumb
Caveat lector
Old 06-10-2007   #5 (permalink)
CLB
My purge connector is a grey 2 pin with a spring wire release.
Brown/Pink is switched 12 volts
Yellow/Red goes to the ECU where it gets grounded to operate the solenoid, should it exist.
I am not certain but I believe non ABS bikes have different harnesses. You shouldn't have an ABS connector.
Have you removed or had SAI removed?
Are you sure the white two pin isn't the fuel sender that you forgot to hook back up? :-D
Photo?
I just noticed that OND mentioned the alarm connector. On my machine it is a black 12 pin connector loosely clipped to the inside of the right frame member (tends to fall off).
It should not br unused. Without an alarm it should be mated to a two wire loopback connector. It may have appeared unsused at first glance.
[ This message was edited by: CLB on 2007-06-10 11:47 ]
CLB is offline   Reply With Quote
New Info. 12004 Tiger Chat 4 02-13-2007 09:54 PM
NEW HERE AND NEED SOME INFO PLEASE GOATEEGEAR Twins Technical Talk 5 12-14-2006 04:01 PM
rocket cleaning info/clarification of mis-info soberdude The Rocket Science Forum 14 10-27-2006 12:30 PM
info need dragline708 Speed Triple Forum 0 06-12-2005 01:21 AM
'05 ST info dmbikerguy Sprint Forum 16 06-11-2004 05:23 PM
