Motorcycle.com
Old 06-09-2007   #1 (permalink)
03 st, 40k
Full tank, Fuel Gauge doesn't come off the peg, low fuel light solid on.
I tried hittin every bump I could find thinking maybe a stuck float, but no joy.
Any experience here lads ?
Cheers y'all, Cyn-
First you take the test,
then you learn the lesson!
Members Album
CYNCRZR is offline   Reply With Quote
Old 06-09-2007   #2 (permalink)
Favorite Bike: '02 Sprint
Cyn,
The fuel sender is an occasional failure item. Unfortunately, it's in the tank so the tank needs to be removed and the plate on the right side taken off. On the bright side of things, if it failed completely, the engine warning light would also come on, so at least that hasn't happened.
If you do wind up replacing the sender unit, you should also replace the fuel filter (if you haven't yet).
Bern
PaloAlto is offline   Reply With Quote
Old 06-09-2007   #3 (permalink)
Your sensor unit should be the ball in the tube design. quite possible it is stuck. May have to drain the tank and pull the sensor and try fiddling with it outside the bike.
If you get it out and find that the ball moves but still doesn't work, it could be toast. Should be able to use a multimeter and read the resistance on the leads as the ball rises.
That's about all I know on that design
ROWYKO!
xactoman is offline   Reply With Quote
Old 06-09-2007   #4 (permalink)
Thanks guys, let me ask ya this since me and Electrcity... well lets just say that I'm challenged when it comes to this part of things..
But if a connector had come off would it give the symptoms I described ?
Cheers y'all, Cyn-
Members Album
Old 06-09-2007   #5 (permalink)
CLB
Loose connector should also throw a code and check engine light.
CLB is offline   Reply With Quote
o7' tiger fuel low fuel light spezz1 Tiger Chat 5 06-04-2007 09:54 PM
low-fuel warning light problem robbie0365 T3 Sport / Touring Forum 5 02-25-2007 11:37 AM
Fuel Gauge OK, Low-Fuel light intermittent andy-D Tiger Chat 3 11-16-2006 04:46 PM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 08:18 AM
Fuel Guage & Low Fuel Light Fatbob Tiger Chat 4 08-09-2004 04:33 PM
