My RS's check engine light just came on - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-24-2007, 09:58 AM   #1 (permalink)
Favourite Bike: Whatever I own right now
johnshumpert's Avatar
Other Motorcycle: 2007 Triumph Bonneville
The light came on last night. The mileage just ticked over 6,000.
I have noticed a problem with low rpm surging. It's worse when the weather is warm. There's a flat spot in the lower rpm range, but at times it almost feels like I've dropped a cylinder and I have to get the motor around 4k rpms before I feel that third cylinder kick in.
Recently, when riding around 5k rpms and I hit it hard, there's a slight hesitation, almost like it's slipping. That wasn't there before but the bike's always been a little quirky below 3k rpms.
The power in the normal rev range feels fine. I'm wondering if I need new spark plugs? Any ideas? I'm taking it to the dealership to be checked out later today.
Thanks,
- John
johnshumpert is offline   Reply With Quote
Old 05-24-2007, 10:38 AM   #2 (permalink)
gazza's Avatar
My light came on every once in awhile at about that mileage. I didn't have any performance issues though. My dealer said it may be just loose wiring.
After a while it just stopped. I can't verify if they traced it down during the service or not.
When riding, always wear a long-sleeved shirt. It gives you something to wipe your nose on.
gazza is offline   Reply With Quote
Old 05-24-2007, 10:53 AM   #3 (permalink)
Favourite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
If the MIL light came on, that means that the ECU has logged a fault. the dealer, or a mate with a tuneboy should be able to tell you what code was stored.
This should give you at least a starting point on a diagnosis.
"Any fool can criticize, condemn, and complain - but it takes character and self-control to be understanding and forgiving."
chefjpd is offline   Reply With Quote
Old 05-24-2007, 01:21 PM   #4 (permalink)
SHVAK
Mine also came on just after the two year warranty ran out. No abnormal effects on performance however. Dealer diagnosed it to faulty ECU chip and repaired it under warranty. Would have cost me over $400 otherwise.
check engine light jinxx1313 Triumph SuperSports 10 05-24-2008 06:14 AM
Check Engine Light HTH13 Tiger Workshop (archive) 5 03-08-2008 02:01 PM
check engine light Quietsouls Maintenance & Workshop Talk 6 12-24-2006 10:33 AM
check engine light robbo1847 Maintenance & Workshop Talk 4 07-17-2006 04:35 PM
Check engine light Speed Triple Forum 1 07-02-2004 02:19 PM
