I decided to check my plugs tonight and I had the tank off for maybe the 4th time since I've owned the bike. Never paid much attention to where the two black (appear to be vent) lines go, but tonight as I was putting it back together I noticed the end of these hoses aren't connected to anything. One has a valve in it and the other does not. I am 99% sure the one with the valve is a vent line and just needs to be routed to down through the frame/engine, but is the other black line also a vent line that connects to nothing? It is also ran down there, but just wanted to make sure before putting it all back together.
Also, does it matter which of the two lines goes on which nipple on the tank? The one with the little valve was originally on the rear connection on mine, but thought while I was asking I would ask about this also. These are the two small black hoses that connect to the nipples coming straight out of the bottom of the tank (above all the other lines) There is a 3rd black hose that comes out vertically and goes to the airbox.
I can take a picture if it will help, but hopefully you all will know what I'm talking about as you all have been a HUGE help in the past!!!!
Thanks in advance,
Shane
