AdvanstarMotorcycleShowsBikeBanditTrident-Exhausts.comMotorcycle.com
Old 05-10-2007   #1 (permalink)
Favorite Bike: '01 Sprint ST (RED)
Hokie's Avatar
Other Motorcycle: '99 Suzuki DR650SE
I'm planning to pull the rear off tonight for the first time to take it in for new rubber tomorrow. I've read several threads on here regarding this, but thought I should ask just to make sure I didn't miss anything.
I picked up a 1 13/16" socket as suggested in MANY threads and know that I need to pull the exhaust can off to get access to the nut. Also read the torque should be 108 ft/lbs.
Anything else I should be aware of before getting into this? It looks fairly straight forward, but thought I should check.
Thanks in advance,
Shane
Hokie (Shane)
Hokie is offline   Reply With Quote
Old 05-10-2007   #2 (permalink)
undo the nut and pull tire/wheel off.. much fast/easer then most bikes.
stinky93071 is offline   Reply With Quote
Old 05-10-2007   #3 (permalink)
Hokie's Avatar
:-D :-D :-D :-D
Thanks! that's what I was thinking, but just wanted to make sure there wasn't a secret trip wire connected to a springie thingie with a sensor wrapped around it and threaded through a fitting that would all fly out in 50 directions when I removed the wheel. You know, like most things I try to take apart.
-Shane
Hokie (Shane)
Old 05-10-2007   #4 (permalink)
Favorite Bike: '03 Sprint ST
Hokie,
Note which way the locking pin is inserted, so you put it back in the same way. I then secure the pin with a small black ziptie.
Also, although you don't mention whether you have bags, I'll say that when I pull my rear wheel, I take the two 8mm bolts out of the front (latch0 mount, and muscle the hanger to the outside of the peg bracket. That gives you the room to get the wheel on and off.
Lastly, when you go to put the wheel on, wrap a small rag over the hub, so you don't accidently grrr up your wheel as you wrestle is back under the bike.
HTH
pushr0d is online now   Reply With Quote
Old 05-10-2007   #5 (permalink)
Hokie's Avatar
Great tips! I do have the bags. Thanks!!!!
Hokie (Shane)
Old 05-10-2007   #6 (permalink)
Favorite Bike: 08 Sprint ST
Other Motorcycle: Yamaha YZ426f
When putting the wheel back on make sure the pins on the hub go back into their round holes, not the spaces between.
When pulling the wheel you'll find that the nut, washer and spacer, goes into an insert in the wheel that can, and probably will, fall out. Keep track of the order of washer and spacer.
You CAN break loose the nut without help, or a massive extra arm on the socket. Put the bike on it's centerstand. Put the bike in gear. Rock the wheel up against the transmission resistance. Place a block between the tire and the ground to assist in resisting turning. With your right foot apply the rear brake. Then loosen the nut using a normal breaking bar(I use a 1/2 inch drive one about 16" long myself). Reverse direction of block to torque when putting wheel back on. Though, the block may not be neccessary if your rear brake works well enough, and you've got the resistance of the motor to assist. It's just extra help.
World Storehouse of Useless Knowledge
Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence, or stupidity.
SprintST is offline   Reply With Quote
Old 05-10-2007   #7 (permalink)
duckie's Avatar
Great advice SprintST
Haven't done it on the sprint yet but the front sprocket requires a bit more gymnastics if it's anything like doing it on my sv650s as you have to lean over the bike whilst standing on the rear brake and then try to put some muscle into your breaker bar without scratching any paintwork... of course you could be less prideful and ask your wife / friend for some help... :razz:
duckie is offline   Reply With Quote
Old 05-10-2007   #8 (permalink)
Hokie's Avatar
I was thinking of putting the bike on the centerstand and having my wife sit on it and rock it back on the rear wheel with the brake engaged while I try to break it loose. Surely that would be sufficient.
-Shane
Hokie (Shane)
Old 05-10-2007   #9 (permalink)
Just apply the rear brake with one hand and crank the nut off the axle.
oldgoat57 is offline   Reply With Quote
Old 05-10-2007   #10 (permalink)
click here
this is for the Daytona, but you'll get the idea, just take your sweet time around the bag mounts etc and you won't scratch the rim
you may also consider letting some air out of the tire to have more room to manuever (AMMV)
"Exoriare aliquis nostris ex ossibus ultor."
REGULATOR is offline   Reply With Quote
17"rear wheel tridentman T3 Sport / Touring Forum 7 04-09-2007 03:14 PM
Rear wheel banging around - Watch that rear axle nut! n578md Twins Technical Talk 6 09-17-2006 01:49 PM
Any tips for aligning wheel after new chain? timyjimy Triumph SuperSports 6 08-21-2006 04:07 PM
Looking For Two Up Tips And Rear Pegs... Sprocketjockey Daytona Deliberations 3 03-07-2006 08:16 AM
Rear Wheel DMc Sprint Forum 1 05-17-2005 05:20 PM
