Sounds like the factory is adjusting the beams properly on the 07's.
When my 06 was new, the beams were angled severely down, giving me no forward vision above the cutoff.
Each time I rode the bike at night I wondered...
Just recently I think I cracked the code and you have to agree with item 'a' and 'c' before reading on....
a) The beams are shaped like a soup bowl.
b) The horizontal cutoff is the rim of the soup bowl...
c) Your beams are way too low and equal, so that when you corner, there is nothing illuminating your path.
Here's how I fixed mine:
Adjust the rim so it's above the oncoming car and will not blind the them. Even with a pillion, this beam will not blind others.
The 'edges' of the soup bowl have a slightly higher intensity, these are your cornering beams that lay down as you lean into a corner.
The bottom of the soup bowl should be at road level, this is not an intense beam, but enough to see in front without the main beam on.
I think Silver Stars or similiar adjusted this way will increase forward illumination yet not blind others.
[ This message was edited by: airrider03 on 2007-05-09 07:47 ]
