Old 05-08-2007   #1 (permalink)
Do the 05-07 Sprint STs use a standard type of headlight bulb? Can I buy one at any auto parts store?
Also, how hard is it to replace? I can't tell if I'll have to remove body panels or not. Hope not. :-D
-- Joshua D. Scott
-- '06 Sprint ST (Blue - ABS)
jdscott74 is offline   Reply With Quote
Old 05-09-2007   #2 (permalink)
Aske's Avatar
I can't remember off the top of my head if it's an H4 or H7 bulb (it's printed on the headlight assembly glass, though). It's a simple replacement, and I had little trouble reaching the low-beam bulbs without removing anything from the bike. Or myself, for that matter. NTTAWWT.
"Try to become not a man of success, but try rather to become a man of value."
2006 Sprint ST/ABS (Sunset Red): going, going, ... gone
Aske is offline   Reply With Quote
Old 05-09-2007   #3 (permalink)
Thanks so much Aske! I'll check it out and try to replace it myself then.
-- Joshua D. Scott
Old 05-10-2007   #4 (permalink)
I pulled the bulb last night, and it's an H7, 55W.
The bulb is behind the circular rubber covers that sit below the dash, one on each side. After removing the cover there is a clip that you squeeze loose, and then the bulb can be removed from the wiring harness.
I'll try and get some pictures when I go to replace the bulb, for everyone's future reference.
[ This message was edited by: jdscott74 on 2007-05-10 09:34 ]
-- Joshua D. Scott
Sprint St 955i Headlight Bulb Replacement RonnieD155 Sprint Forum 10 08-15-2007 02:50 PM
replacement headlight bulb ORCA Speed Triple Forum 1 03-22-2007 05:41 AM
Headlight Bulb Replacement - 2001 Sprint ST IronRAT Sprint Forum 6 12-06-2005 10:12 PM
Advice on Headlight Bulb Replacement Options TripleThreat Speed Triple Forum 10 12-02-2004 05:24 PM
Headlight bulb replacement PeterB Hinckley Classic Triples 2 04-18-2004 03:54 PM
