BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 05-08-2007   #1 (permalink)
STcharlie's Avatar
Hi Gang,
My scooter picked up a nasty habit...the front end gets a little squirrelly especially when a big wind blast hits it. This new sensation started late last year, and I felt it again over the weekend. It's not tires as those have been changed. I'm going to check the head bearing and the tension on the head nut (no, not mine, the bikes). Any suggestions for procedures here and tension settings on the head nut (again, not mine...).
Thanks,
Charlie...
See My Photo Album
STcharlie is offline   Reply With Quote
Old 05-08-2007   #2 (permalink)
Favorite Bike: 01 Sprint ST
Other Motorcycle: 82 Yamaha Vision
Extra Motorcycle: Another 82 Yamaha Vision
I am having the exact thing happen with me...Seems like around trucks I start to get speed wobble when going above 75. I dont notice any wobble but have yet to do the real check. I also have new tires so i know that isnt the problem. Today I am going to see if it can be tightened.
Haynes says to put front wheel up on stand. Grasp Fork sliders and push them forward and back. Looseness will be felt in this direction if head bearings need tightening or replacement.
kwellzz is offline   Reply With Quote
Old 05-08-2007   #3 (permalink)
Favorite Bike: 2001 Sprint St
MVP44's Avatar
Other Motorcycle: 2003 GSXR 1000
This could also be a result of running tire pressure up just a wee bit. Try taking say .5 psi out just to increase the contact patch a hair and see if the instability improves - this is a quick check before looking elsewhere. Just a thought
MVP44 is offline   Reply With Quote
Old 05-08-2007   #4 (permalink)
you might be right about pressure. I dont have a pressure tester but will check that today. I did notice a couple issues in doing the head bearing tightening. 1. Getting the front wheel up. I put it up on the centerstand and used a ratchet tie-down strap connect to the luggage rack and ran it to my car. Simply ratcheting it down raises the front wheel securely. 2. The adjuster nut is very skinny and without completely taking off the yoke I was unable to get to it. A skinner spanner tool would be able to get this.
I did not feel any play in the head bearing when pulling front to back on the front end so I think it may be the tire pressure.
Old 05-08-2007   #5 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
kwellzz, you gotta get a tire gauge and use it regularly.
Oldndumb
Caveat lector
Old 05-08-2007   #6 (permalink)
I have been using Roadgear's digital pressure tester for 3 years now and I really like it. It's easy to get a seal and the gauge is sized well. Two guys I ride with also use them.
http://www.roadgear.com/catalog/detail.cfm?Prod_ID=196
RoadGear Gauge
[ This message was edited by: chiefsr on 2007-05-08 12:54 ]
Don't be scared to wrench on it...humans came up with it, humans fix it, you're human, right?
chiefsr is offline   Reply With Quote
Old 05-08-2007   #7 (permalink)
I had 2 but my car got broken into and they friggin STOLE IT...how lame is that. Will get another today
Old 05-08-2007   #8 (permalink)
oh yeah, what pressures are most running? I was thinking of 38/42 but that might a bit high.
Old 05-08-2007   #9 (permalink)
I run 36/42
Old 05-08-2007   #10 (permalink)
cricket1's Avatar
I run 33F/36R
36/42 is a MAX pressure. I would only use that if riding 2 up, with luggage at 80MPH on the freeway, in July! Way too high any other time.
'03 Sprint ST
Mods: 18T, Gen Mars, Heated Grips, SilverStars, Mufflectomy, Stebel Horn, Pazzo Levers, Corbin GF & L, SkyKing Sliders, NEP
cricket1 is offline   Reply With Quote
head light adjustment bete Sprint Forum 2 03-14-2007 06:08 AM
head bearings on a s4- adjustment...? johnnycactus Triumph SuperSports 3 09-09-2006 02:06 PM
head light adjustment Robdan Sprint Forum 0 07-23-2006 03:41 PM
steering head bearing adjustment zmann Speed Triple Forum 10 10-25-2005 09:24 PM
05 Head Lamp Adjustment 2cats Speed Triple Forum 6 10-15-2005 08:20 AM
