BikeBanditTrident-Exhausts.comAdvanstarMotorcycleShows
Old 05-07-2007   #1 (permalink)
anyone got a pix of the headlight adj bolts, I am going to try to adj. the HL with out taking the fairing off thanks Ron
OOOOOO is there a service manual on this site
ronniena is offline   Reply With Quote
Old 05-07-2007   #2 (permalink)
I don't have a pic, but I know from experience you can easily change the hight position of the beam without taking off the fairings using a stubby philips screwdriver.
Shawn Mahoney
Cuyose is offline   Reply With Quote
Old 05-07-2007   #3 (permalink)
Favorite Bike: '02 Sprint
You can use a shorty screwdriver as Cuyose mentioned or try a socket on an allen wrench. Neither is particularly easy in the small space but it's doable. And you definitely do not need to take the fairing off.
Each bulb has two screws. The one on the outside of bulb and high is the horizontal adjustment. The one on the inside of the bulb and low is for vertical.
Bern
PaloAlto is offline   Reply With Quote
03' T100 Bobber Zansongs Twins Technical Talk 22 07-20-2007 09:28 AM
06' undertail ex. on 03' ronniena Sprint Forum 7 06-09-2007 04:31 AM
03' t-100 Bonne bcaruso166 Twins Technical Talk 12 02-28-2007 09:58 AM
03' recall ronniena Sprint Forum 2 03-28-2006 02:13 PM
03' Sprint ST decals ronniena Sprint Forum 0 09-04-2005 11:18 AM
