Motorcycle.comAdvanstarMotorcycleShowsBikeBandit
Old 05-06-2007   #1 (permalink)
Finally, got off my butt and decided to throw the risers on. I had done a little searching on here and it looks like some had clutch cable problems and some didn't. So I went with the clutch side first.
No way it's going to happen. I moved the cable around to the other side of the yoke and it still binds. I can't see any other way of running this thing to make it work. I also had some problems getting the spacer to fit into the stock bar. I finally just gave up.
So some install help would be greatly appreciated. Pictures would be even better. I'm guessing I got the right risers. I believe the part number was T118. Thanks for whatever help you guys can give.
crashdb is offline   Reply With Quote
Old 05-06-2007   #2 (permalink)
No one?!?!?
Old 05-06-2007   #3 (permalink)
Favorite Bike: T595 Daytona
Tankman's Avatar
Other Motorcycle: Kawasaki 1400 GTR
Extra Motorcycle: Z1502 Kawasaki-6
Crashdb,
I found that when I installed my Genmars although the clutch cable fitted, it was still tight. I took it to Cable Guy here in Hobart and had it lengthened by 32mm which worked a treat.
Good luck The Tankman
[ This message was edited by: Tankman on 2007-05-07 04:47 ]
"Britannia Still Rules The Waves"
"If you want to be a big dog, you got to piss on big trees"
Tankman's Photos
Tankman is offline   Reply With Quote
Old 05-07-2007   #4 (permalink)
Thanks. You don't happen to remember which part number you received do you?
Old 05-07-2007   #5 (permalink)
Tankman's Avatar
Sorry no mate, I bought my risers off DaveM second hand. They were for a 04 Sprint but fitted my 05 ok.
Cya The Tankman
Tankman's Photos
Old 05-08-2007   #6 (permalink)
T118 is right.
I have the same ones, and was lucky enough to get them installed without a problem or need for longer cables. I didn't even re-route them.
-- Joshua D. Scott
-- '06 Sprint ST (Blue - ABS)
jdscott74 is offline   Reply With Quote
Old 05-08-2007   #7 (permalink)
Did you have to move the cables out of the guides or holders or anything? I emailed Gen-Mar and they're telling me that the clutch cable needs to be removed from the guide. I'm sort of flying blind. The bike is at a storage unit and I haven't had a chance to stop by and look at these things again.
Old 05-09-2007   #8 (permalink)
Got them to work. And this is what I did:
I moved the clutch perch inward on the bar. That helped give some room. I also rotated the perch a little. Then on the throttle side I had to rotate the brake line off the master cylinder down a little and then did the same with the perch. It's still a little tight, but I guess it'll work.
I don't have any riding impressions. I did this on the way home from work this morning. I did ride it around the storage facility a little. Seemed to be a big difference.
Gen Mar Handlebar risers vintage96e Trophy 5 05-17-2007 11:49 PM
gen-mar vs jenks risers HowieL Twins Technical Talk 3 09-01-2006 05:07 PM
Gen-Mar Bar Risers mnmrosen Trophy 6 05-20-2005 09:22 AM
Gen Mar Problems angusclay Sprint Forum 6 05-13-2005 09:56 AM
Anyone with and RS have the Gen-Mar risers? jellero Sprint Forum 7 04-22-2004 06:22 PM
