2003 Sprint ST Low Battery Voltage. - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsNew BonnevilleOntario Tourism
Old 03-12-2007, 12:49 PM   #1 (permalink)
mcfan
The clock and tripmeter on my 2003 ST have ceased to work correctly.
The clock only works when I have a 1 amp trickle charger plugged in, and the tripmeter, while it works, will zero itself and switch back to the odometer whenever the bike is turned off.
I've installed a new battery, but the problem persists.
My dealer said that this might be caused by low battery voltage....has anyone else had this problem, and if so, how did you solve it.
Thanks for any help.
Old 03-12-2007, 01:34 PM   #2 (permalink)
Favourite Bike: Sunset Red 06 Sprint ST ABS & Silver 05 Tiger
airrider03's Avatar
How about the rest of the bike?
Headlights, running lights, etc., high load items.
All I can think about is some hidden connection that's possibly dirty/corroded. Put a meter on the battery terminals and light the headlights...what happens to the reading????
The positive cable comes from the battery and bolts to something...look there if needed.
Good luck!
Stay Still, and roll the Earth beneath your wheels...
airrider03 is offline   Reply With Quote
Old 03-15-2007, 09:07 AM   #3 (permalink)
Favourite Bike: 2003 Sprint ST
Does the bike fire-up normally?
Does the battery goes flat if you're not using the bike?
etc...
Check that the connections on the battery are tight.
Reseat the fuses, check for corrosion.
SpiderTex is offline   Reply With Quote
Fix for low voltage found Sasquatch Tiger Chat 14 04-03-2008 07:33 PM
What Voltage should Battery Be At? gmarotta Sprint Forum 14 10-24-2007 09:05 PM
low battery txpete Twins Talk 8 02-03-2007 09:50 PM
Battery Voltage humbug Daytona Deliberations 7 04-14-2006 03:53 PM
Low Battery voltage causes ECU problems! Prubert Speed Triple Forum 0 02-12-2005 05:06 PM
