You are in luck. I just did this today and it was WAY simpler than I thought.
Yes, there is definitely enough room to change it out without taking off the chain.
I actually didn’t change the chain, but can give a couple pointers on the sprocket replacement with existing chain.
First, you will need a 36M socket. Go to Sears, it is under $10. You will also need an 18m socket for the swing arm pinch bolt. Then you will need the 10m socket for the sprocket cover.
Take the cover off. You will see the HUGE nut on the front sprocket with a washer that has a side bent in to make sure the nut if it comes loose doesn’t twist off.
Use a screwdriver and hammer or something to bend this back flat.
Use your honkin 36m socket to remove the nut and washer thing. I found it wasn't torqued on super tight.
At the back wheel use the 18m socket and loosen the pinch bolt.
Now use your triumph spanner tool for adjusting the chain, if you don’t have this it looks like you could use a big pipe wrench but I am not sure. As you turn this you will immediately see the wheel move back or forward. It’s a cam so if you keep turning it it will go from tight to loose.
Once you find where it is loosest, run the slack part of the chain up to the front sprocket and remove the sprocket with chain attached off the spindle. You will have to work it around a bit to remover the 19T from in there, don't worry it will come out and the 18T is easier to get back in.
Do everything in reverse to button up.
One HUGE note is to turn the tire before tightening the pinch bolt down. I found that I was 180 degrees out of adjustment and the tire was scraping on the mudguard. It totally through me for a bit as it didn’t make any sense. If you take the spanner and keep rotating the adjuster it will scoot back down where it doesn't rub. You will see what I mean if you encounter this.
Good luck!
[ This message was edited by: Cuyose on 2007-03-10 19:00 ]
Shawn Mahoney
