BikeBanditTrident-Exhausts.comAdvanstarMotorcycleShows
Old 03-10-2007   #1 (permalink)
Chris90
Hi there,
I was doing some work on my Sprint RS (early model - to vin 139203) when I noticed a problem with the hose that's connected to the fuel pressure regulator.
For starters the hose is quite badly split. But more alarmingly, while one end is connected to the regulator, the other end is not connected to anything.
So can anyone tell me where the other end is meant to be connected to? Also, I don't know how long the hose has been like this. So will it have caused any damage to any components? Finally, what would be the best sort of hose to use as a replacement?
Thanks in advance for your help
Chris
Old 03-10-2007   #2 (permalink)
I would suggest that you take the hose and place it in the nearest trash container and forget about it. The newer Sprints don't have that hose. I'm not sure when that change occurred but on your bike there should be a nipple for it to slide onto the bottom of the air box. It is totally unnecessary for it to be filtered air as it is only to equalize pressure and doesn't go anyware (that is the air doesn't go into something that could get screwed up).
Universal Laws of MC Forums
1. Just because the engine is on and the wheels are turning doesn't mean you're "riding".
2. The bike you ride and the farkles you buy have no correlation to how good a rider you are.
3. The ignorant can be enlightened, but the stupid just drive on forever.
rodneybrown is offline   Reply With Quote
Old 03-10-2007   #3 (permalink)
My 03 doesnt have this and if it was connected to the airbox, I agree you can just toss it, but if it did route to the airbox, I would take a stab at finding where it did and taping up the opening.
the opening prolly isnt very big, but will definitely effect the amount of air entering the airbox and treak your mixture a bit.
Shawn Mahoney
Cuyose is offline   Reply With Quote
Old 03-11-2007   #4 (permalink)
Chris90
Hello again
Just a few lines to say thank you for the advice that has been offered.
A closer look at the hose showed that it was not as bad as I first thought - it was just the ends that were badly split. As it was just a simple rubber hose and quite a generous length I simply cut the ends and refitted it.
Sure enough there was a nipple on the bottom of the airbox and I've now connected the hose up to it - thanks for that info.
cheers
Chris
Fuel pressure regulator carr955 RAT - United Kingdom 9 11-25-2007 06:11 PM
Fuel pressure regulator? desmo955i Daytona Deliberations 2 04-27-2007 11:13 AM
Fuel pressure regulator? Nickwiz Daytona Deliberations 14 11-30-2006 04:00 PM
Fuel Pressure regulator zore Sprint Forum 22 09-12-2005 09:53 AM
Fuel pressure regulator Saigon5 Sprint Forum 4 08-13-2005 01:31 PM
