Ok, it would seem my st has started to make a peculiar noise. I first noticed it when i was at a stop light and once i started to move I would hear some kind of noise from under my bike. After listening, I realized the noise only appeared when I stop and start up again. Today I decided to try and figure out what that noise was. I started just by hitting the gas like i normally would at a stop light then hit the brakes again and discovered that the sound only appeared when I used the rear brakes. So then I decided to try pushing the bike then hitting the rear brakes and that made the sound oh so clear and fairly loud. Basically it sounds like a clicking noise (think of the noise a zip tie makes when you are tightening it - but slowly - that's what it sounds like). I have absolutely no clue what is causing this, does anyone have any thoughts or possible troubleshooting ideas? Any help would be appreciated. Thanks!
