AdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
Old 08-26-2004   #1 (permalink)
hi could any of you guys post the socket size for the rear wheel nut on a 2004 Sprint ST
also has anyone had a problem with a minor mist type
oil leak from the head gasket area on the R/H side on the bike nothing too bad just a film which builds up over a week of use ( 400 kms ) just annoying from a otherwise flawless
bike bought the bike (new) in Feb 2004
We have been notified in N.Z. for the fuel fittings recall
they will be replaced at the next service
RAT NZ is going from strength to strength great bunch !!
bernie s
bernie is offline   Reply With Quote
Old 08-26-2004   #2 (permalink)
The rear wheel nut size is a nutty 46mm. I also understand that a 1 13/16" socket will also work. As I recently took off my rear tire, I can tell you it's a buggar to get the nut off. It also requires about 100 ft/lbs of torque when you reinstall it.
Tom
'01 Sprint ST (Oh boy its a fast red one)
thfwsf is offline   Reply With Quote
Old 08-26-2004   #3 (permalink)
Actually I should clarify that. I used a 1 13/16 socket to get my rear tire off.
Old 08-26-2004   #4 (permalink)
A much more manageable 27MM on the RS dual-sider. The front is a 19MM (or 3/4") hex (Allen) head.
bikesdp is offline   Reply With Quote
Old 08-27-2004   #5 (permalink)
Hi all,
Actually the nut is 46mm but the 1 13/16 is smaller and fits it better. Get 5 ft bar to put on the end of your breaker bar or you're NOT going to get that thing off.
Preachp
Cruisin\' the byways of life for Christ
preachp is offline   Reply With Quote
Old 08-27-2004   #6 (permalink)
I hear ya preachp. I used a 18" breaker bar and I was actually standing on the thing to break it free. I was starting to wonder if I was going to break my breaker bar!!!
Yes, if you can, get a nice long breaker bar. These nuts are a PIA to get off of the SSSA.
Tom
'01 Sprint ST (Tornado Red)
Old 08-27-2004   #7 (permalink)
Hi Thfwsf,
I hear you brother, speaking from the school of bleeding knuckles!
Preachp
Rear Wheel Removal - size of nut 45mm? geelongrat Sprint Forum 12 02-22-2008 08:32 PM
What size is the rear wheel nut Limey Speed Triple Forum 16 12-12-2006 05:31 PM
Rear wheel nut size, 02 Sprint RS sjestory Sprint Forum 3 01-18-2006 11:06 AM
Rear wheel nut size,00 Sprint ST? Dirtybill Sprint Forum 4 01-18-2006 12:16 AM
Rear Wheel Nut Size??? nyspeedtriple Speed Triple Forum 3 08-03-2004 03:02 AM
