The Widder vest is a great product. You want the BMW cord for the Sprint. Also, I strongly suggest you get the vest with the collar - its nice to put up the collar under your jacket when its realy cold. Finally, if you are on the bike for longer than 30 minutes at a clip, I would recommend that your get the variable heat controller (product code N-4 for BMW version) The variable lets you really dial in the most comfortable setting. With the switch its Hot/OFF/Hot/OFF.
