BikeBanditTrident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 08-24-2004   #11 (permalink)
Favorite Bike: 2003 Sprint ST
I'm checking for leaks tonight...
thx T.D.
SpiderTex is offline   Reply With Quote
Old 08-24-2004   #12 (permalink)
bluedogok
On 2004-08-24 04:14, SpiderTex wrote:
[snippage]
Sorry for asking the obvious but: You don't kill the engine with the kill switch? right? And you don't touch the throttle when starting?
Success with finding a solution.
I think what SpiderTex is talking about is the Sagem ECU does not like to be shut down via the kill switch, it does some "logging off" type of procedure when using the keyswitch. When you use the kill switch, it is effectively like unplugging your computer like a power interruption and COULD corrupt the ECU programming.
I have read about this issue on other forums with other manufacturers that use the Sagem ECU (I think Aprilia uses them also). Not sure if this is the case, but I think that may be what he is referring to. I used to use the kill switch, a habit from the old dirt bike days, but now I use the key, unless I accidently put the sidestand down without thinking.
[ This message was edited by: bluedogok on 2004-08-24 19:25 ]
Old 08-24-2004   #13 (permalink)
I understand - I have always used the key to turn of my bike. I am still leaning to wards a program problem in handling poor fuel quality.
An for the Aussie's - I am not using Shell Optimax.
[ This message was edited by: TassieDevil on 2004-08-24 20:07 ]
TassieDevil is offline   Reply With Quote
Race Tune vs. Off-Road Tune- Mattsy Tiger Workshop 16 07-11-2008 05:14 PM
tridents to tune or not to tune ???? scoobydoo Sprint Forum 4 01-13-2008 02:06 PM
TORS tune from dealer or Tuneboy tune? Max_NYC Speed Triple Forum 25 07-06-2007 10:22 PM
Tune # chukus13 Speed Triple Forum 6 07-31-2006 09:51 AM
S3 vs ST tune DaveC Speed Triple Forum 1 08-14-2005 08:50 PM
