The 'best' oil filter for your bike is made by Purolator for the Mazda! The Pur-One part # PL-14610 is also only about $5.50 at your local Pep Boys. (yes, Manny, Moe, and Jack) If you value that fine triple you will avoid any filter with the Fram name on it! They are great at marketing, they're everywhere, but they are also 'JUNK'.
Follow this link for some interesting information on oil and air filters...........
Oil & Air filter report
Draw your own conclusions after reading a bit about filters. The stock Triumph filter (toko-Riki) is a good filter, it's just not the best or worth any where what the dealer gets for it.
And yes I use the Purolator. In fact I just stocked up on a few, seems that part # is getting 'real' popular and is frequently out of stock! A side bonus is it is just a bit longer than a stock one so you don't need any special tools to remove it. It is still not lower than the pipes or the belly pan if you have one installed.
A side note:
This site shows many filters that are alternatives to the stock filter. It is an FVR site, but that particular Honda filter is a direct replacement for the Triumph unit as well. The Honda filter is a good quality unit. You might find some of the pictures of the cut-away filters interesting. Also another site that steers very clear of all things Fram!
Oil filter cross reference
[ This message was edited by: Stlakid on 2004-08-18 14:40 ]
