Motorcycle.comBikeBandit
Old 01-11-2007   #1 (permalink)
Favorite Bike: 06 Sprint ST 1050 ABS
KevyKev's Avatar
Other Motorcycle: 91 Suzuki Katana 600
Hello all. I popped this question into another thread but guess we should start a new thread.
The 07 ECU is supposedly a more powerful and upgraded ECU. Does anybody know or does anybody have techie access to find out if we could simply swap a 07 ECU into a 05/06 Sprint? Do you think that it would be a simple 'plug-n-play' type swap or is more involved?
That all being said, do you think it would be a worthwhile add-on?
Thanks! :hammer:
KevyKev is offline   Reply With Quote
Old 01-11-2007   #2 (permalink)
Favorite Bike: Sprint ST 06 Blue
I would like to know also, although I suspect it won't worth the $. I guess it will be too expensive.
Nikos
Do you want to participate in an off-the-beaten-track tour of mainland Greece?
Check below for the big Sprint ST Greek Tour being organised for Spring '08
http://www.triumphrat.net/rides-events/68872-greek-bike-tour-next-spring-anybody.html
NikosR is offline   Reply With Quote
Old 01-11-2007   #3 (permalink)
GRN
What I heard from the two dealers here was very similar... which doesn't mean it's right...
New ECU:
- doesn't have the multi rev firing delay, so the engine starts faster. The feeling here is that it was considered a problem in some markets, and would make the bike seem.... better in some way? I think having the engine turn a few times to move some oil prior to firing makes good sense myself.
- improved fuel economy, if you look at some of the comparos done, the Sprint is on the weak end for fuel economy... another market driven concern?
- neither dealer believed that the new ECU would have a significant impact on dyno stats, nor was it remapped/designed with that concern in mind.
I don't know how much if any of this is true... seems details are hard to come by with Triumph in this regard. I'm still trying to get measured specs on the '07 bar difference... all I can seem to get is "higher", or, "higher and a bit further back". Not clear why such a simple detail isn't easily found :???:
[ This message was edited by: GRN on 2007-01-11 11:41 ]
Half as many wheels, at least twice as many good ways to get there! :-)
Asphalt Junkie, Fly Fishing Fanatic, MSF RiderCoach
'06 Sprint ST (little faster beaST), '04 ST1300 (BIG blue beaST)
GRN is offline   Reply With Quote
Old 01-11-2007   #4 (permalink)
KevyKev's Avatar
GRN --- I agree. The 'few' seconds (if even that long) of extra cranking before starting really does not bother me. It hasn't been an issue for me. A little better MPG never hurts, but, the bike is already better than my car and I enjoy 'wicking' up the Sprint too much, so I'm not real concerned about the fuel consumption :-D
A couple extra ponies would be nice too, but if I recall correctly this also made the motor a little peakier. Not necessarily a good trade off for my street riding.
Plus, god knows how much big T will charge for a new ECU. I'm dying to get a TOR or other equivalent eventually for my performance gain. I'm just interested to know if we COULD swap the ECU's without a problem. :hammer:
Old 03-16-2007   #5 (permalink)
wheelspin63
The price of the 07 ECU is plus US$1600.00! Alot of sheckels to spare a few extra turns of that sweet triple!
Old 03-16-2007   #6 (permalink)
I believe the 07 has different fuel injection too, so not sure how the 07 ECU is configured or programed for that system. Seems that the different fuel injection system would be managed differently, perhaps different inputs or software code.
spits71 is offline   Reply With Quote
Old 03-17-2007   #7 (permalink)
KevyKev's Avatar
$1600 !?!?!? I knew I was happy with my 06! No need to change to that ECU.
Old 03-17-2007   #8 (permalink)
CLB
Look at the air/fuel maps. Below are links to the 06 and 07 Air/Fuel maps. Notice that much of the 06 and earlier tables are above redline and below idle. The 07+ tables are revised to add more RPM points around cruise.
It's almost as if a generic ECU were quickly pasted onto the 05/06 bikes.
The 07 ECU on the other hand appears to be optimized for the Sprint RPM range.
The files are ~200k so I've posted links instead of graphics.
06/07 stock tune is 20104
07 stock tune is 20113
Contrary to other postings here the 07 tunes will not load into an earlier ECU
You may need to expand or enlarge the jpegs for a good view but detail is there.
06 Air/Fuel map.
07 Air/Fuel map.
Notice the raised or lean area around idle and cruise. I believe this accounts for much of the improved starting and MPG. The 05/06 machines gas foul unless you blip the throttle to give them more air.
If you really want to get into this go to tuneboy.com, download tune edit and the maps of interest. It doesn't cost anything to look.
[ This message was edited by: CLB on 2007-03-16 23:43 ]
CLB is offline   Reply With Quote
Old 03-17-2007   #9 (permalink)
I have an 07, still runnig it in, how many miles should i get from the tank on the new mapping and what should be the average MPG.
cheers
Born2ride is offline   Reply With Quote
Ecu ? triumphtimes Speed Triple Forum 0 09-16-2007 04:12 PM
ECU for R3 alselec The Rocket Science Forum 0 07-19-2007 07:51 PM
Tuneboy install time? And ECU question. PROMOD1385 Speed Triple Forum 9 07-13-2007 05:36 PM
07 ECU Stampy Speed Triple Forum 10 03-02-2007 10:02 AM
ECU map question Hairball Speed Triple Forum 4 10-17-2005 09:16 PM
