BikeBandit
Old 01-11-2007   #1 (permalink)
Favorite Bike: 2003 Sprint ST
Hi, need your advice folks...
I'm currently running on Roadtec Z6 and am very happy with this tyre.
However I changed jobs => more stress => less time => company car => less kilometers...
So I was wondering to go for something softer, the new Sportec M3 for example.
My current rear Z6 is getting pretty used but my front still has a good chunk of kilometers in it.
Do you think I could couple a rear Sportec M3 with a Roadtec Z6 front? Or rather go for another rear Z6?
Metzler comparison chart, click on Street Products:
Metzler clicky
SpiderTex is offline   Reply With Quote
Old 01-11-2007   #2 (permalink)
Favorite Bike: Sprint ST 06 Blue
These tires are entirely different animals.
I've learned never to pair a sticky rear with a less sticky front, although the opposite is not usually a problem. Also their profiles should be different with the M3 less round in shape.
I wouldn't do that, but then I often have to ride on very slippery Greek surfaces.
Nikos
Do you want to participate in an off-the-beaten-track tour of mainland Greece?
Check below for the big Sprint ST Greek Tour being organised for Spring '08
http://www.triumphrat.net/rides-events/68872-greek-bike-tour-next-spring-anybody.html
NikosR is offline   Reply With Quote
Old 01-11-2007   #3 (permalink)
NikosR, thanks. Now that you mention it, it doesn't sound like a good idea...
Roads in Belgium are not the best around either...
/off topic sad but true * those who have driven in the German Eifel will understand/
Q: When riding those nice roads in the Eifel - Ardenne, how do you know if you crossed the German - Belgian border (driving into Belgium)?
A: When it starts to feel like you riding off-road (bumps, potholes etc)
Old 01-11-2007   #4 (permalink)
Moderator
Favorite Bike: Blue 08 Tiger -Current
ruscook's Avatar
Other Motorcycle: White07 SpdTrple -crashed
Extra Motorcycle: Red 06 Sprint -Sold
You want the stickiest tyres that will give the distances you want. For me that's a sport touring tyre. For DaveM that's full sports tyre.
As for mixing tyres, I agree with Nikos completely. You can (and quite often should) put a stickier front on so when you're pushing hard you're less likely to lose the front. The worst this does is give equal mileage from front and rear and increases your confidence. At best, it means you won't lose the front end - which is a hell of a lot harder to bring back or control than a rear end slide ;-)
Russ
ruscook is offline   Reply With Quote
Old 01-11-2007   #5 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
SpiderTex,
I would agree with the other guys, in fact I do not like mixing tyres at all myself.
The tyres you refer to most likely not only have vastly different compounds but the tread patterns I believe should be made to match, in other words stick to a set.
Handling problems can ensue when you start mixing thigs up, though you will always find someone who says I used this with that and it was ok.
But that is my opinion and others may disagree.
If you want a sportier tyre how about a Michelin Pilot Power?
They steer very fast last a reasonable while (not too soft) and stick real good handle nicely but are a bit twicthy in the front.
just a suggestion.
DaveM
DaveM is online now   Reply With Quote
Old 01-11-2007   #6 (permalink)
On 2007-01-11 06:13, DaveM wrote:
SpiderTex,
Handling problems can ensue when you start mixing things up, though you will always find someone who says I used this with that and it was ok.
just a suggestion.
DaveM
Hi Dave,
long time no see... errr read...
how is the crock? Still around or sliced onto sandwiches?
I was contemplating the Michelin Pilot Power as a confirmed good alternative, the Metzler Sportec M3 is pretty new, so need to do get some benchmark results.
I will stick [ahem] with the Z6 and use up the front and rear. Then switch to something softer.
Old 01-11-2007   #7 (permalink)
DaveM's Avatar
Sounds like a plan spidey.
Where have you been hiding mate?
DaveM
Old 01-11-2007   #8 (permalink)
DaveM
In a circus called the rat-race :hammer:
How's life on the otherside of the globe...
Old 01-12-2007   #9 (permalink)
DaveM's Avatar
Hi Spidertex,
yeah it's all ok down under mate.
I must say it's nice to hear from you again, I'm glad you got a little time out from the rat race then.
You always have interesting comments to make.
Try not to be away for so long!
DaveM
roadtec z6 may be toast? PtboSprintSt Sprint Forum 2 11-04-2007 09:10 AM
METZELER ROADTEC Z6 loveTrumpet T3 Sport / Touring Forum 8 11-21-2006 12:28 PM
Metzler Sportec M-1 Tires Daytona Deliberations 2 11-05-2004 11:39 AM
Metzeler Z6 Roadtec Tire LegendGirl Hinckley Classic Triples 1 04-23-2004 05:48 PM
Anyone have the Metzler Sportec M1 's? Triumph SuperSports 8 12-19-2003 09:48 AM
