don't everyone try to post at once... i was going to put a speed bleeder (check valve) on some tubing to bleed the brakes and then found a gadget at napa that is just that, tubing with a check valve on the end. it is called a "one man brake bleeder". just fill the master cylinder, open the bleeder nipple and pump the brakes until the fluid comes out clearer, then close the bleeder. you just changed the fluid. j
