Dual Star heated grips install qustions - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismNew BonnevilleSportbikeTrackGearMotorcycle.com Classifieds!
Old 01-05-2007, 10:56 AM   #1 (permalink)
I have heard about a wire you can tap into to install these but have no clue where it is or how to get to it..
can anyone help?
stinky93071 is offline   Reply With Quote
Old 01-05-2007, 03:20 PM   #2 (permalink)
Favourite Bike: 2005 Sprint ST 1050 Blue
DrTriumph's Avatar
you can hook into the factor grip wires, do a search for heated grips lots of information in this forum.
Dr Triumph
My Photo's...
DrTriumph is offline   Reply With Quote
Old 01-06-2007, 01:25 AM   #3 (permalink)
i guess i am doing somthing dumb can when i do a serch for them i get nothing. can you put a link up?
Old 01-06-2007, 07:26 PM   #4 (permalink)
Here's a post from this website that I cut and pasted. It was EXTREMELY helpful when I installed Dual Stars on my 05. Good luck.
Kevin;
Yes, I just put the DualStars on my '03 Sprint last week. They work great! I have no comparison to the Factory ones, as these are the first heated grips I have ever had. I got the three position round plastic switch and left bar insulator that dual star sells. The install under the factory grips was easy. Use a butter knife w/ some dish detergent on it, grips should come off no problem. When re-installing them over the heated elements, I used some hairspray on the inside of the grip, and on the bar, slips on easy, dries tight.
Make sure you buy a 12 v. automotive relay. Tap into the special wiring in the left side of the fairing for the factory heated grips. MAKE SURE YOU DO IT with the relay. I tried both wiring it directly to the unswitched wire, which works great, but if you EVER leave it switched on, it will flatten your battery, or using the switched 12v wire, problem with that is it doesn't get anywhere near as hot, and takes longer. Use the relay and have the best of both worlds.
I also drilled a small hole in the left fairing below the left grip to mount the switch, looks factory. Be careful when you do this!
FYI- on the special wiring harness, the black wire is the ground, purple is unswitched 12v, and grren/ grey is switched 12V.
I got this advice from CLB on this board about the relay:
The grip heat connector on my '06 is located under the headlight on the left hand side of the fairing.
The connector has 3 wires. Those wires are ground, constant 12Vdc and switched 12Vdc.
If you have a meter you should be able to figure out which is which.
If you don't have a meter... Buy a meter.
Automotive relays generally have their terminals labeled 30, 85, 86, 87 and SPDT relays have an additional 87A contact.
It doesn't matter if you buy an SPST (4 terminal) or SPDT (5 terminal) relay. If you buy an SPDT (5 terminal) relay you will leave terminal 87A unused.
Buy a relay without a coil diode so you cannot wire it backward.
Wire ground from grip accessory connector to terminal 85.
Wire switched 12V from grip accessory connector to terminal 86.
Wire unswitched or constant 12V from grip accessory connector to terminal 30.
Wire terminal 87 (normally open) to your heated grip power switch and on to the heater elements.
That's as easy as I can make it.
-Zach
Towelie is offline   Reply With Quote
Old 01-07-2007, 12:04 PM   #5 (permalink)
wow, wish i got that yesterday when i was installing them. I will go back and do it over next time i have the bike apart.
thanks for the info..
and if you do not have these thing and have ever thought about getting them go for it well worth the $30. Get them they are nice..
Installed Dual Star handgrip warmers today (with pic of switch placement) Catamount Speed Triple Forum 7 10-29-2006 08:37 PM
Dual Star v. Triumph heated grips KevinR Sprint Forum 6 10-13-2006 02:14 AM
Dual Star Heated Grips- Help! cricket1 Sprint Forum 13 10-04-2006 12:00 PM
Heated grips install madmic Tiger Workshop (archive) 1 08-09-2006 02:21 PM
Integrated Heated Grips install Gragorin T3 Sport / Touring Forum 6 12-04-2005 11:16 PM
