Adjusting fork preload - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Honda PowersportsNew BonnevilleOntario Tourism
Old 01-02-2007, 08:19 AM   #1 (permalink)
Favourite Bike: Sprint ST 06 Blue
What do you use to adjust the fork pre-load. If the new Sprints fork screws are made from the same kind of butter-metal the old ST's were made of, I wouldn't want to cause any cosmetic damage.
Nikos
NikosR is offline   Reply With Quote
Old 01-02-2007, 01:32 PM   #2 (permalink)
Other Motorcycle: Daytona 600 called Kryton
Its the same on any marque of bike mate (especially Suzuki I might add) - the oem fasteners are made of cheese :-D
Kev
Why is there so much month left at the end of the money?
Thefallenone is offline   Reply With Quote
Old 01-02-2007, 04:35 PM   #3 (permalink)
ST
Favourite Bike: R3
ST's Avatar
Other Motorcycle: 1050 tiger
The secret is to use a screwdriver as wide as possible and the correct thickness tip to avoid it twisting in the slot. Ideally make a homemade one with aluminium by using a flat sheet of 18swg alloy plate. If the bike is on the main stand with no load on the forks this will assist slightly in turning your adjusters.
Or ask your dealer to do the adjustments next service.... if he fudges the adjusters 'smile' as you ask for them to be replaced.
[ This message was edited by: ST on 2007-01-02 15:51 ]
ST is offline   Reply With Quote
Old 01-02-2007, 04:36 PM   #4 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
NikosR,
Kev is right unfortunatley they are made of cheese.
I would try to find a very wide bladed screw driver.
I have marked my own adjusting them also, very annoying I know.
If you have a workshop I'd make something specifically for it.
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 01-03-2007, 07:28 AM   #5 (permalink)
Thanks guys. I'll try to get hold of the widest screwdriver I can find. Ideally it should fit and allow some space to use a piece of soft cloth as well to try to protect the fork screw.
Nikos
Old 01-09-2007, 03:58 AM   #6 (permalink)
If you take a large coin (a quarter works pretty good here in the USA) and some needle nose pliers you can move the adjusters without damage. Just be careful to make sure the coin is firmly placed in the slot before turning.
Jed
Flylow is offline   Reply With Quote
Old 04-12-2007, 10:12 PM   #7 (permalink)
I would agree.
Posting my first 10 to be able to PM Pierre for the manual. Picking up bike tomorrow. 10,300 out the door for demo w/ 900 miles, but ABS. I am very happy at 8999.00 plus fees. In the showroom and mint. I'll be back to tap the knowledge fountain here. Thanks!
1050Rokker is offline   Reply With Quote
Preload fork caps powerdarko Hinckley Classic Triples 4 02-07-2008 05:08 PM
Minumum Fork Preload superduty Speed Triple Forum 2 07-03-2007 12:10 AM
Installing Thrux adjustable fork preload fork caps - Issues? ohiorider Twins Technical Talk 1 04-24-2007 12:42 PM
adjusting preload pinballjon Sprint Forum 4 09-12-2005 06:37 AM
adjusting rear spring preload punisher Triumph SuperSports 3 06-10-2004 03:13 AM
