Bleeding the Brakes - I need a How-To - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 08-07-2004, 01:22 PM   #1 (permalink)
Well, I successfully changed my oil last weekend. I don't have an owner's manual, so all the help I got from this forum was a big help. Thanks.
Now, my next project is to flush the brake fluid. I've never bled the brakes on a bike before. Does anyone have any tips about doing it? I have a couple of specific questions also:
First, because the Sprint has triple discs, do I need to bleed the brakes at each caliper? Or, can I just pick one and leave the others alone? (Sorry if this is a stupid question, but I'm pretty clueless about this.)
Secondly, has anyone ever used one of those vaccum tools like a Mighty-Vac to do this job? I read a bit about them, and it seems it might make the job a little easier, and perhaps less likely to introduce air into the system.
Thanks in advance for your help.
PassTheGravy is offline   Reply With Quote
Old 08-07-2004, 02:03 PM   #2 (permalink)
Favourite Bike: sprint
TRIUMF3's Avatar
You will have to bleed all three, the front two are fed by one reservoir and the back one from its own reservoir, as an ade to bleeding try the Speed Bleeders on this page
TRIUMF3 is offline   Reply With Quote
Old 08-08-2004, 12:44 AM   #3 (permalink)
Fronts- pull the lever first while you back off on the bleed screw. Tighten the bleed screw and then let off the lever. Do this until no air comes out of the nipple or you've flushed all the old fluid out of the system. Keep a positive pressure on at all times. Keep fluid in the master cylinder at all times.
Rear- same thing. You're trying to push air bubbles out so maintain a positive pressure on the system. Push on the lever before you open the bleed nipple, and tighten the nipple before you let off pressure on the lever.
If this doesn't make sense, please let me know. Brakes are important, and everyone has to learn sometime.
jeff tarlton
jefftarlton is offline   Reply With Quote
Question about bleeding brakes??? Suncoast Sprint Forum 7 11-13-2007 05:42 PM
Bleeding brakes itcha Club Cafe' 10 06-28-2007 10:57 PM
Bleeding ABS brakes JTXR Sprint Forum 5 06-24-2007 03:05 AM
bleeding brakes abird4 Sprint Forum 7 05-26-2007 09:48 AM
any tips for bleeding brakes? burgessa23 Triumph SuperSports 6 07-29-2005 03:36 PM
