Motorcycle.com
Old 05-29-2005   #91 (permalink)
well, i can't say if this is going to count as a mod but, here it is.
when you fill up your tank from empty (wait for the idiot light), throw in a bottle of octane boost. yep, the whole thing. i have done it to several of my bikes, some give very noticeable results, others don't. anyway, i don't know if it does anything for performance, but i think it has at least helped the mileage on my last tank.
now the disclaimer. the stuff that they use in the octane boost (tuolene) basically amounts to paint thinner. now, the fuel is used to cool the windings on the fuel pump, and they have a varnish on them. so it is possible you could kill your fuel pump with this stuff. be careful with how much/often you run this stuff.
rash
"There he goes. One of God's own prototypes. Some kind of high powered mutant never even considered for mass production. Too weird to live, and too rare to die." - Duke, Fear and Loathing in Las Vegas
rash_powder is offline   Reply With Quote
Old 06-08-2005   #92 (permalink)
On 2005-03-26 13:18, sazerac99us wrote:
I've been looking into the fuel pressure regulator mod (FPR) and talked with one dealer's service guy, that told me the new bikes have an oxygen sensor, and on those bikes, the ECM will cut the fuel injection back to adjust the fuel mixture according to how it is set. So, high fuel pressure, low fuel pressure, the ECM will adjust itself accordingly.
anyone heard something different?
I would think the FI system would have a tolerance range already set, and a sensor to detect whether it goes over or underpressure. I'd have to look again at wiring, and fuel diagrams to be sure.
World Storehouse of Useless Knowledge
Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence, or stupidity.
SprintST is offline   Reply With Quote
Old 06-10-2005   #93 (permalink)
Theo
I bought mine with heated grips pre installed and yes they work... a lot...
I have no clue which of the two selectable settings fries my hands the most, but I have to constantly switch it on and of to not get to sweaty hands.
I use thin summer motorcycle gloves though...
Has any one tried to mod it by adding some potentiometer to better vary the heat supplied?
Old 07-04-2005   #94 (permalink)
only one headlight on with dipped beam?
inside the fairing next to the right hand fork leg is a set of relays. you will see the bottom two slots are empty. one is for the high beam on one light, the other is for the dipped beam on the other.
put in two relays and hey presto, both lights on all the time dipped or full beam :wink:
dave usually, or whatever the wife feels like calling me at the time
davsato is offline   Reply With Quote
Old 07-06-2005   #95 (permalink)
fitting relays ... if you're not using the factory ones you might find as I did that the bottom one falls out.
In part I think this is because the socket can move backwards and sideways in the box in which it sits. You can avoid this by hooking your finger round the back and pressuring the socket when you push the relay in.
I've now wired the relay tab to the wire bundle nearby too so that if it does fall out I can try again ;-}
Cheers, Ern
Motorcycle Sports Touring Club of Victoria, 50th anniversary year, Club website
ST-ern is offline   Reply With Quote
Old 07-10-2005   #96 (permalink)
i know what you mean Ern, the bracket that holds all the relays onto the frame bends very easily.
it must be made out of what we call "monkey metal", a special alloy that pretends to be strong until you really need it, then magically turns to cheese before your very eyes. what Harley Davidsons are made out of.
Old 09-04-2005   #97 (permalink)
Drilling the baffle...why a 1" hole? Just random choice or specific cfm you're after? I'm thinking start smaller...maybe ½" or ¾"? If the sound is still too muffled, go to a larger drill? Also, how 'bout drilling the first baffle first, try it out for power, then drill the second one later if you want?? Just thoughts.
My first aid kit comes with lights and sirens...
Never ride faster than your guardian angel can fly, which is what? the speed of light...
katrider is offline   Reply With Quote
Old 10-03-2005   #98 (permalink)
jvb
I made a 25mm hole because I used a hole cutter. Once you make a hole this way, it is very difficult to make it larger.
I now have two holes, see image below.
I would like to get through to the next baffle, but can't reach it (yet)!
My wife told me I never listen to her.
At least that's what I think she said!
jvb is offline   Reply With Quote
Old 12-11-2005   #99 (permalink)
Favorite Bike: '03 Sprint RS
steventhechef's Avatar
I had the headlight relay mod done about 2 weeks after I picked up my RS. The difference was amazing (pun: black and white) and all for $25 at a dealer too!! I was unsure as how to go about the mod but was told afterwards that it was that easy. The night riding visibility is greatly improved.
Re the CF can. I was lucky enough to have one already on mine and the difference (in attitude and HP) is impressive. Adds a few ponies have been told. I rode a standard RS which was still great but the CF can gave it a much better note and the extra grunt.
After the to and fro-ing of the FPR I am unsure as whether or not to progress with the mod. Any updates on the sensors in relation to the Date of Manufacture? Will my 03 RS get any benefit? :???:
Love the forum. Thanks for the insight.
[ This message was edited by: steventhechef on 2005-12-11 20:01 ]
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 12-28-2005   #100 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
Tire air pressure ( I run 34F/ 37R on pilot powers)
High octane fuel
Bleed front brakes
TORS and new map
New air filter when available, improve airflow.
1 less tooth on countershaft sproket
Stay fit, trim, loose weight if possible!!!
Smile!
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Trying to post a picture or two, of my latest mods Moggy Twins Technical Talk 7 07-21-2007 08:06 AM
Trying to post a picture or two, of my latest mods Moggy Twins Technical Talk 4 07-21-2007 01:53 AM
Scrambler mods;Re- Norman Hyde Post bung1 Twins Technical Talk 8 11-13-2006 10:58 PM
Inexpensive, Effective Suspension Mods Yimm Sprint Forum 3 11-02-2006 09:55 PM
INEXPENSIVE MODS Brit26 Twins Technical Talk 34 09-17-2006 07:22 PM
