Coolant Discharge After Ride - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-28-2006, 10:43 PM   #1 (permalink)
Favourite Bike: My '06 Sprint ST - C/Blue
BallaRAT_ST1050's Avatar
Hey All, Just a quick question . I have a new '06 ST - just had the 1k service last week. About 2 weeks ago did a ride on a hot day (35 C / 95 F) for about 300km, temp gauge never went above 6 or 7 bar and was mostly on the 5 bar.
When I stopped at the end of the ride and turned the motor off the coolant reservoir started to overflow and discharge onto the ground - via pipe underneath. When it cooled down the level had gone from MAX to 1 inch below MIN in the reservoir.
Topped up coolant and the next day it did the same thing.
Dealer inspected at 1k service and said all was OK ????
Should I be worried , I've never had a bike do this before and this is my 6th bike - Any suggestions or comments appreciated
( took cap off radiator when cool and it was full)
Work to Live : Live To Ride
BallaRAT_ST1050 is offline   Reply With Quote
Old 11-29-2006, 12:00 AM   #2 (permalink)
Maybe air in the radiator? There's a bleed screw on the right side of the radiator that should be removed when filling. I think you'll probably need to remove the right side fairing to get to it, but maybe it can be reached through the front. You could try removing the bleed screw with the bike on the center stand and then top off the radiator.
markml is offline   Reply With Quote
Old 11-29-2006, 03:28 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Hi BallaRAT_ST1050,
Or.............. maybe they just over filled it and it's getting down to where it should be.
Havent got any loose or pinched hoses?
Davem
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 11-29-2006, 04:04 AM   #4 (permalink)
Liftetime Premium
Favourite Bike: Grey 2010 K1300R - currnt
ruscook's Avatar
Other Motorcycle: Blue08 Tiger1050 - trade
Extra Motorcycle: White07 SpdTple - crashed
If the temp never got above 7 it's probably the overflow doing it's job as the liquid expands under high temps. Just like a car - shouldn't be an issue.
Keep an eye on the overflow reservoir under the left fairing panel (not whole side panel, the one near the dash, just left of the lights), if this is totally empty, top it up to somewhere about 23-40%. It's my understanding the radiator can both blow and suck (technical terms them) from this reservoir.
Russ
ruscook is offline   Reply With Quote
H.I.D. (High Intensity Discharge) Conversion Kits crowder Twins Talk 1 09-04-2007 08:33 AM
Battery Discharge retrobiker Classic, Vintage & Veteran 7 08-25-2007 03:05 PM
Flushing 01 coolant, no manual? coolant bubbles after use! speedtripleride Speed Triple Forum 1 05-21-2006 12:53 PM
t120v discharge buggy Classic, Vintage & Veteran 3 04-13-2005 03:22 PM
Battery discharge Sprint Forum 4 07-19-2004 11:41 AM
