Front brake hose length on a -2002 ST? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
New BonnevilleHonda Powersports SportbikeTrackGearMotorcycle.com
Old 11-28-2006, 09:49 AM   #1 (permalink)
I will rebuild my front brakes to dual lines and at the same time ad some length to compensate for my higher handlebar.
I found it hard to measure the length of the hose properly without removing it. So therefore I wonder if someone at this forum know the exact length of the original hose?
Speedyswede is offline   Reply With Quote
Old 11-28-2006, 04:49 PM   #2 (permalink)
I'm at work right now, but I just switched my stock lines for braided SS lines. I'll measure the old ones tonight. When you say higher handlebars, do you mean Gen-Mars or something like an LSL conversion. On my 02 ST the Gen-Mars didn't require a longer brake line, nor did my LSL; HOWEVER, the left line of a dual line kit is about 2" longer.
Universal Laws of MC Forums
1. Just because the engine is on and the wheels are turning doesn't mean you're "riding".
2. The bike you ride and the farkles you buy have no correlation to how good a rider you are.
3. The ignorant can be enlightened, but the stupid just drive on forever.
rodneybrown is offline   Reply With Quote
Old 11-28-2006, 05:17 PM   #3 (permalink)
I have the Helibar clamps with a Renthal bar at the moment (about LSL style). I am planning to do the famous "master cylinder swap with double brakelines" fix on my bike. The standard hose length works, but I thought if I added about an inch it would be possible to route it more nicely.
In that case I shall have standard length plus one inch at the left side and plus three inch at the right side then? If I remember correct you meassure the hose at the banjos, center to center?
Old 11-28-2006, 07:14 PM   #4 (permalink)
Favourite Bike: 2004 Yamaha FJR
Doublenikkel's Avatar
Other Motorcycle: 2004 Yamaha FJR
Galfer has custom kits available.Specify your bike and the extra length you want over stock. Ordered mine thru cycle gear and only took a week to get them in.
[ This message was edited by: Doublenikkel on 2006-11-28 17:15 ]
It`s better to put a knee down, than your head!
Doublenikkel is offline   Reply With Quote
Old 11-29-2006, 07:31 AM   #5 (permalink)
I measure 27.5inches center to center but it is not exact because you have a 90 degree fitting on the top end and about a 20 degree fitting on the bottom. I bought my kit through Spiegler and it came with some added length which made it fit well, but you still have to route it correctly.
Hope this helps.
rod
Old 11-29-2006, 08:06 AM   #6 (permalink)
Thanx Rod!
I will order one 29" and one 31"hose.
Steel braided brake hose for rear brake midliferider Hinckley Classic Triples 4 05-20-2007 05:29 PM
front brake hose routing 05Truxter Club Cafe' 2 04-10-2007 08:17 PM
New (used) Bike, Front brake hose length? xactoman Speed Triple Forum 3 10-12-2006 05:46 AM
Changed the front brake hose - the old boot and my son lent a hand too. keef Twins Talk 7 09-26-2006 08:38 PM
Brake Line Length Fishtale Sprint Forum 1 09-26-2004 05:11 PM
