Rear hugger for '06 ST - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleMotorcycle.comMotorcycle.com Classifieds!Ontario Tourism
Old 11-28-2006, 12:14 AM   #1 (permalink)
Favourite Bike: Sprint ST 06 Blue
Has anybody fit a rear hugger to their 05 or 06 ST? I see Jack Lilley (UK) list one on their site.
Any experiences?
Nikos
NikosR is offline   Reply With Quote
Old 11-28-2006, 12:29 AM   #2 (permalink)
Favourite Bike: 06 Sprint ST ABS red
iceman's Avatar
yes - here is a photo of my Powerbronze 'carbon look'.
Good fit and approx 1 hour to install.
There are a few other aftermarket ones available but Triumph wont sell them as an accessory.
Grant
iceman is online now   Reply With Quote
Old 11-28-2006, 12:34 AM   #3 (permalink)
Did you have to drill any new holes to get it installed?
Nikos
Old 11-28-2006, 04:02 AM   #4 (permalink)
Favourite Bike: T595 Daytona
Tankman's Avatar
Other Motorcycle: Kawasaki 1400 GTR
Extra Motorcycle: Z1502 Kawasaki-6
NickosR
The powerbronze hugger is a good quality piece of kit. No you don't have to drill any holes, but one tip is put the securing nut on top of the hugger. Good luck and safe riding.
Cya The Tankman
"Britannia Still Rules The Waves"
"If you want to be a big dog, you got to piss on big trees"
Tankman's Photos
Tankman is offline   Reply With Quote
Old 11-28-2006, 04:46 AM   #5 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
NikosR,
I have one like icemans on my '04 it is good quality stuff like Tankman says.
I know it's a different model but same brand as icemans.
cheers,
Davem
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 11-29-2006, 05:56 AM   #6 (permalink)
OK. I've just ordered my Powerbronze carbon-fiber look hugger for my '06 ST through a local dealer. Won't be here for at least 3 weeks I'm afraid.
I like huggers. They seem to keep lots of the crud off the shock and the rest of the bike. I used to have the Triumph one on my '99 ST.
Thanks for the pics and the comments.
[ This message was edited by: NikosR on 2006-11-29 04:00 ]
Nikos
Old 11-29-2006, 06:13 AM   #7 (permalink)
Favourite Bike: Triumph Sprint 1050
Good looking pic iceman. smart hugger and clean looking bike. How is the hugger held in place as the ABS version does not have the tapped holes in the swing arm?
He who dies with the most toys wins.
gavinb is offline   Reply With Quote
Old 11-29-2006, 08:30 AM   #8 (permalink)
Hi guys. Fitted a Powerbronze hugger to mine too. Just don't follow the instructions that come with it unless you remove the rear wheel first. I attached the frame to the hugger first , then loosened and removed the rear caliper to get the hugger under the brake line, then bolted it all down without having to remove the wheel (I didn't have the necessary tools at the time for removal).The only slight modification was that two of the holes were approx 5mm out of position on the hugger and I had to oval these out to get a line up for the bolts. :hammer:
ewan is offline   Reply With Quote
Old 11-29-2006, 01:03 PM   #9 (permalink)
iceman's Avatar
Gavin, the hugger has a steel bracket which uses the same bolt holes as the original chain guard.There are some photos in my album of the bits and a before,during,after sequence.
It all went together as per the instructions without removing the wheel.I had to file one of the holes in the plastic slightly bigger as I couldnt get the rubber gromet in place - but no big deal.
Probably half the time was spent cleaning all the crud from around the shock,etc.
Tankman and whisperinsmith have both put the 2 bolts that hold the hugger to the bracket in upside down as they felt that the ends of the bolts got too close to the tire.Mine seems ok - looks to be at least 6mm or so clearance and no sign of any interference.
Grant
Old 11-29-2006, 02:17 PM   #10 (permalink)
Favourite Bike: '07 Tiger
Whisperinsmith's Avatar
Other Motorcycle: '06 Sprint, sold along with '05 America and '69 Bonnie
Extra Motorcycle: 200cc cheap dirt bike
As Iceman said, I did reverse the bolt and nut arrangement and even with that I got a scar on my new rear tire!
I've been reading this post debating whether to mention I'm taking my hugger off my bike. Don't misunderstand, if the hugger doesn't rub anything or hit when going over bumps, then I love it. Keeps everything back there nice and clean.
I mentioned this in a previous post, but worth repeating. Since I got my new tires (Metzler Sportex M3), the hugger has given me problems. I think the new tires have a higher, rounder profile and therefore "hit" the hugger. I had to bend the frame up in order to avoid more scrapping. Then I noticed the hugger itself was hitting on the left side near the rear footpeg protection bracket.
Maybe I ride very bad roads! (Glad I just got a cheap dirtbike.)
Too bad because I loved the function of it. But on the positive side, I seem to be the only one here that's had any problem.
Good luck with yours.
[ This message was edited by: Whisperinsmith on 2006-11-29 12:32 ]
Life. Fill 'er up. It's all we got.
http://www.armchaircommando.org/benn...Bash/Home.html
Bennington, VT May 31, June 01 2008
Whisperinsmith is offline   Reply With Quote
rear hugger joejay70 Sprint Forum 17 05-13-2007 07:44 PM
looking for a rear hugger PROMOD1385 Speed Triple Forum 10 05-13-2007 02:49 PM
rear hugger ricster Sprint Forum 11 01-14-2007 09:31 PM
Rear hugger buz Sprint Forum 2 08-28-2005 08:26 PM
rear hugger for d9 Daytona Deliberations 2 06-08-2005 02:30 PM
