clonking noise pulling away - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-26-2006, 12:11 PM   #1 (permalink)
955i ST, about 12k miles on the clock
i get a clonking noise as i let out the clutch and pull away in 1st. you can also feel it through the pegs, it doesnt do it in other gears, only happens when i slow to a stop using engine braking, so ive got a bit of play in my drive train somewhere.
i thought it was the chain so ive just done a chain/sprocket change, its all new and adjusted properly but still clonks.
any ideas? do the cush drive rubbers go this early?
dave usually, or whatever the wife feels like calling me at the time
davsato is offline   Reply With Quote
Old 11-26-2006, 04:32 PM   #2 (permalink)
Favourite Bike: 1966 Bonnie
amanger's Avatar
Have you checked the rear wheel bearings?They are known to wear out fairly quickly.
"Fusion White" Street Triple, Arrow 3>1 + Power Commander III, DNA Filter, No O2 sens. ,No SAI, Flyscreen + Visor,R&G Tail Tidy, Triumph Tail Bag, Pazzos,Gel Seat,Radiator Cowl,Hugger,Crash bungs, Grabrail.......
Old 11-26-2006, 07:09 PM   #3 (permalink)
Favourite Bike: '02 Sprint
Dave,
A low probability item is the rear brake calipers. They should have very slight forward/rearward play in them allowed by a pin in a slot. But I think there have been a few reports of something going awry and the calipers having way too much movement. Admittedly, this doesn't correlate with the clonk occurring only after engine braking - OTOH, if this occurs only when you don't use the rear brake, maybe there is a correlation.
Bern
PaloAlto is offline   Reply With Quote
Old 11-27-2006, 02:02 PM   #4 (permalink)
Favourite Bike: Daytona 675
Has the rear wheel become loose on the centre, try loosening the centre nut and re-torque. I experienced exactly this once, just one clonk as you take up the drive. It may help to clean the cone and wheel seat in case there is a trace of grease. Best of luck
StevyR is offline   Reply With Quote
Old 11-27-2006, 03:56 PM   #5 (permalink)
thanks for the help fellas,
wheel/hub bearings fine
brake caliper fine
chain/sprocks fine
with a mate on the ground and me pulling away next to him to trace the noise we came up with two possibles;
1/ the chain was slightly baggy (pilot error) and slapping the underside of the swingarm, easily remedied but not today, so watch this space,
2/ the cush drive maybe slightly loose, in 1st gear with the bike on the ground and the rear brake on hard, i brought the clutch in as hard as i could without stalling and there was some play in the cush, perhaps 1/2", i dont know how much play there should be but thats less then some bikes ive had, can anyone tell me? its not sloppy, i cant move the hub around against the brake by hand
i will let you know tomorrow what effect the chain tightening had :???:
Old 11-27-2006, 05:45 PM   #6 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
davsato,
or if it's not that you may have accidently hopped on a Ducati by mistake and that would explain all the loud noises! :-D :-D :-D
Sorry mate I couldn't resist that.
Seriously I hope it is a minor issue you can fix easily and cheaply good luck.
Davem
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 11-28-2006, 02:25 PM   #7 (permalink)
no it doesnt sound like a cupful of bolts in the engine, its just a "clonk"!
no, its not the chain i adjusted it a bit tighter and its definately not that.
Old 11-29-2006, 12:56 PM   #8 (permalink)
Favourite Bike: '03 Sprint ST
pushr0d's Avatar
Other Motorcycle: 2000 Sprint ST (wrecked)
Extra Motorcycle: 1988 FXR Lowrider (sold)
Dave,
My '03 has been doing the same thing. I haven't had any luck trying to determine the source.
The only thing I can think of is a faulty chain, but I would assume I would have some other indications.
pushr0d is offline   Reply With Quote
Old 11-29-2006, 01:09 PM   #9 (permalink)
pushrod,
ive just changed my chain and sprockets thinking the noise was that, but its still there.
Old 11-30-2006, 01:00 AM   #10 (permalink)
Favourite Bike: 06 Sprint
Other Motorcycle: SV 650
davsato,
I've had a clunking noise just after taking off from a stop. It drove me nuts not knowing what it was. Turned out to be the inside seam of my boot catching the edge of the foot peg as I would take off from a stop. The peg would fold up, then clunk back down before I put my foot on it. OK, I know it sounds dumb, but go out to the bike, fold the peg up and let it snap back. It's worth a try!
ventur4th is offline   Reply With Quote
Pulling the trigger tomorrow! PROMOD1385 Speed Triple Forum 4 03-19-2007 05:10 AM
TBA pulling to the right? HELP!!! dseely Twins Technical Talk 6 11-17-2006 04:28 PM
Am I pulling to many RPMs medicinthewind Trophy 8 07-24-2006 08:23 PM
Pulling Gas Tank Kieran Sprint Forum 2 10-16-2005 03:34 PM
Problem pulling MikkiStorey Speed Triple Forum 10 07-07-2005 09:01 AM
