If you are a lot lighter or a lot heavier than the target demographic you may need to have your springs replaced too.
First thing is set your rider sag. That's when you set the spring pre-load to get a certain mm of sag when your on the bike.
Next check your static sag, basically how far the bike compresses under just the load of the bike (no rider). This number will change every time you reset your rider sag due to the change in pre-load on the spring.
If the static sag is way off then your spring has too much or not enough preload (due to an incorrect spring).
If the static sag is too little – the spring is too soft.
If the static sag is too much – the spring is too stiff.
When your checking sag, bounce the bike (whether your on it or not) to get the shock in it's natural resting place. There may be some stiction and bouncing will settle it in.
It is possible to order springs/valves from race tech or elsewhere. You tell them height/weight/riding style and they send you a recipe. However, my recomendation is to bring it in and have it done. You need special tools to do valves/springs/oil levels and knowledge. If you just want to do what you can, do some research on spring preload, compression damping and rebound damping. You can fiddle with your clickers and pre-load to get it as close as possible without a teardown.
[ This message was edited by: frizbee_dog on 2004-07-29 16:14 ]
fast... cheap... good... pick two.
