Hey,
You guys need to take a look at the "Helmet Guardian" which is available thru a number of aftermarket cycle out fits, or from Irv Seavers BMW in Orange county if yer' in the LA area. I just did a quickie search and found over a dozen hits for vendors.
Well made, black powder coated, ez to use, and...it works great with the factory bags. I've hung two helmets w/the bags with no trouble. It is essentially a steel replacement for the normal rear license plate bracket with 2 key lockable latches for the helmet D-rings.
I might suggest securing it with something a bit more secure than the provided 1/4"-20 stainless nut/bolts that come with it.
I used 1/4" aircraft Hi-Locks with jam nuts. If you are'nt familiar with Hi-Locks, they 'look' like a large steel rivet, ie: smooth buttonhead with no apparent way to hold it for a nut install. But, they have a very small hex recess for a small allen wrench in the shank of the bolt/screw. Very strong, very secure...most dim witted yahoos would'nt be smart enough to figure out how they work or how to remove them!!
I was considering the Barenders for quite a while, but I want to reserve the bar ends for a Throttle Miester for those long boring runs on the superslab.
Dan'l
So. Calif.
[ This message was edited by: yerguy on 2004-08-02 20:07 ]
See my photo album
