AdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
Old 07-26-2004   #1 (permalink)
hi, i installed sliders on the weekend, have to take side fairings off to have room to work (looks goood) installing the fairings back on i came up with some problem the left & right fairings left an ugly gap, tried to force it together but didn't work. ( there was a slight gap when started but sims like it got wider :???:
Old 07-26-2004   #2 (permalink)
Favorite Bike: 2003 Sprint ST
Weird, shouldn't do that.
Check to make sure that all the lips of the fairing slided correctly in place, that no cable or something like that gets jammed in between the fairing and a piece of engine/chassis/support...
If it realllly doesn't fit, seek your dealer to help you out... since you bought the bike new should be handled as a customer service thingy IMHO
good luck
[ This message was edited by: SpiderTex on 2004-07-27 17:39 ]
SpiderTex is offline   Reply With Quote
Old 07-27-2004   #3 (permalink)
rechecked & everything looks in place, no cables or wires jammed. i will live the bike to warm under the sun and try to readjust it, heard that the fairing is easier to work with when its warm.......heard anything on that????
Old 07-27-2004   #4 (permalink)
Favorite Bike: 2002 Sprint ST
J2, It sounds like you misaligned one of the fairing holes to a tab. Around the front by the radiator it's easy to do. I'd take the whole thing off and try again.
Don
Old 07-27-2004   #5 (permalink)
Easier to work in the sun??? no way, these are high grade sturdy panels....
see Don's advice, something must have slipped when mounting....
success
Old 07-28-2004   #6 (permalink)
don, does your fairing have a gap on that location? if so, how wide? i just cut to size a piece of dark protective vinyl and stick it on that location, it looks nice, no more gap & it adds some protection to the paint too.(similar material to the clear tank guard) spiderT your right no fun working under the hot sun, will enjoy the sun lounging with a couple of 6 packs instead..... :razz:
Old 07-28-2004   #7 (permalink)
Put the fairings in the freezer and the bike in the oven. It works for wheel bearings. :-D
fast... cheap... good... pick two.
frizbee_dog is offline   Reply With Quote
Old 07-29-2004   #8 (permalink)
Hi J2,
I really don't have any gaps either on the fairing sides or at the front below the rad. It takes a little wiggling but fits fine. I don't tighten up the fastners till I get it all fit though.
Don
Old 07-29-2004   #9 (permalink)
What happened once to me, I was fiddling with the fairing for hours until I noticed that I had a part of fairing under one of the connecting lip and that one of the metal clips went AWOL!!
Took everything off again, found the clip (after hours searching, tucked behind the dampening foam glued on the inside of the left fairing :razz: ) put everything together and presto...
job done
Tbird Sports faring mac74 Hinckley Classic Triples 16 02-10-2008 11:15 PM
06 Sprint ST lower right faring? lcdtmd Sprint Forum 14 06-25-2007 04:48 PM
removing faring omahasp3 Speed Triple Forum 5 04-20-2007 02:45 PM
PArabellum Faring for a Bonnie barryd Twins Talk 9 10-23-2005 05:31 PM
Single headlight or faring for an RIII? Deuce The Rocket Science Forum 9 10-03-2005 12:19 PM
