There are lots of possible solutions to the "throttle hold" issue. It really comes down to "How Much $" and "How are You Going to Use it???"
I had an inexpensive NEP lever-type throttle lock on my old Suzuki, and I loved it. I bit the bullet and put the ThrottleMeister on the ST (I'll admit to being a gadget geek...). It really doesn't work very well for me. Most of my riding is country back-roads, with only a bit of highway when I really need to get somewhere quick. I got real used to flipping the lever, shaking and stretching my hand and then flipping the lever back and continuing...the whole process took only a few seconds. With the ThrottleMeister, the process is not nearly as quick, therefore I can't safely use it as much as I'd like. If you are going to do a bunch of straight line driving, then the ThrottleMeister would work just fine...It truly is a quality part, but when I get some time I'm going to try to fit a cheapo throttle lock on the ST...or try a couple of the "Rubber Band" methods... Hope that helps...
Charlie...
