BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 10-29-2006   #1 (permalink)
Favorite Bike: 06 Sprint ST 1050 ABS
KevyKev's Avatar
Other Motorcycle: 91 Suzuki Katana 600
Hey all. Sorry if this has been answered before, but I could not find what I wanted by searching the forum. I have read and understand most everything re: the adjustment. BUT, I am wanting to know if the 35-40 mm of free play measurement is TOTAL of BOTH the up and down movement OR is it just 30-45 mm of UP (or just down) movement?? Can't seem to find an answer.
TIA
Kevin
KevyKev is offline   Reply With Quote
Old 10-29-2006   #2 (permalink)
Favorite Bike: 06 Sprint ST ABS red
iceman's Avatar
.... its from where its hanging to as far as you can push it up.
And better slightly too loose than too tight.
Grant
iceman is offline   Reply With Quote
Old 10-29-2006   #3 (permalink)
KevyKev's Avatar
Thanks Iceman... that's what I thought since 35-40 seemed awful tight for both up and down total.
[ This message was edited by: KevyKev on 2006-10-29 15:25 ]
Old 10-31-2006   #4 (permalink)
I don't like to disagree but the manual talks about "vertical movement" and shows a double headed arrow both up and down so I would say that the 35-40 mm is total (i.e. up+down) play. On my bike the downwards play is about 5 mm. The manual is a bit vague about whether chain slack is measured with the bike on the main or side stand. My guess is that it should be measured with the bike on the main stand since the instruction is to rotate the rear wheel to find the tightest point.
However I'm always willing to learn...
kneedown is offline   Reply With Quote
Old 10-31-2006   #5 (permalink)
KevyKev's Avatar
Kneedown.... the vagueness of the manual was what sorta prompted my question also. I was originally thinking the same as you were, but not 100% positive. But, 35-40 mm is, what, about an inch and a half or so? I was thinking that might be too tight for TOTAL up AND down movement, considering from hearing that the single sided swingarm is better a little loose. Regardless, I have yet to adjust mine! :-D I too have been looking for the "answer" :???:
[ This message was edited by: KevyKev on 2006-10-31 14:59 ]
First Chain Adjustment drharveys Twins Technical Talk 15 03-06-2008 03:44 PM
chain adjustment tshadow6 Twins Technical Talk 7 11-08-2007 09:17 AM
Chain Adjustment question Trophy 5 10-09-2007 06:18 PM
Chain adjustment question stu Sprint Forum 5 09-26-2007 10:06 PM
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 5 11-22-2005 07:11 AM
