In fact Iggy you have the better engine in a lot of aspects. He's a few of the better features.
Firstly having the alternator inboard as opposed to being out in the battle collecting dust and gravel is a good thing.
So too the starter sprag. The early engines up to '94 had a very convienient cover over the sprag making it a fairly simple task, but no where as easy as your machine. The entire starter system is very conienient to service now, just don't loose the wavy washers and spacers found on the shafts.Also when rotating the engine you need only to remove the plug on the RH engine cover (17mm) rather than remove an entire cover and having to fit a new gasket.
Bigger inlet valves, shorter pistons, shorter cam chain, smaller gudgeons,cnc machined head spheres incorporating a specially machined, 'flash-over' shield at the spark plug opening, the list goes on....
oh yeah, and no tool required for shimming
Good machine Iggy, love these engines
