Motorcycle.comAdvanstarMotorcycleShowsBikeBandit
Old 10-19-2006   #1 (permalink)
Do you have to re-route the front brake line or do the risers go straight on.
Going to buy and fit some tommorrow, but flying blind on how they install :???:
Rammstein is offline   Reply With Quote
Old 10-19-2006   #2 (permalink)
Favorite Bike: T595 Daytona
Tankman's Avatar
Other Motorcycle: Kawasaki 1400 GTR
Extra Motorcycle: Z1502 Kawasaki-6
Mate,
they are very easly fitted with a little amount of fuss. I found that in the end I had to lengthen my clutch cable by 32 mm. Anyway good luck and you will find a vast improvement in the ride position and comfort.
Cya The Tankman
:-D :-D :-D
"Britannia Still Rules The Waves"
"If you want to be a big dog, you got to piss on big trees"
Tankman's Photos
Tankman is offline   Reply With Quote
Old 10-22-2006   #3 (permalink)
Favorite Bike: the one I'm riding
Other Motorcycle: 06 Sprint
Extra Motorcycle: 07 Scrambler
You may need to re-route the front brake line. The stock clutch cable should work but you will need to move it a bit.
86gn is offline   Reply With Quote
Old 10-22-2006   #4 (permalink)
Favorite Bike: 1965 Honda S65, 06 Sprint
lcdtmd's Avatar
I too had to reroute the front brake line and the clutch cable. It looks a little goofy, but I had to reroute the clutch cable behind the triple trees. That was the ONLY WAY it was going to work on my 06 Sprint ST. In talking with a local dealer he said there is some variability from bike to bike.
lcdtmd is offline   Reply With Quote
Old 10-22-2006   #5 (permalink)
Mine fitted ok
Had to re-route brake line slightly.
Went on in 10 mins. Bought form Trumpy dealer so do not know what brand they are.
Going to be more comfortable riding to Phillip Island in Feb for Supers
Old 10-22-2006   #6 (permalink)
I put Gen-Mars on mine. Very easy to install, but I had to re-rout my brake line. The clutch fit fine. I think the risers are mandatory, it's the first thing I put on my ST.
dalebuna is offline   Reply With Quote
Old 10-23-2006   #7 (permalink)
SoCalSprint's Avatar
I guess Triumph got the message, new '07's have higher and slightly pulled back bars.
SoCalSprint is offline   Reply With Quote
Old 10-23-2006   #8 (permalink)
Favorite Bike: 2005 sprint
rodsprint's Avatar
Other Motorcycle: gs 550
Extra Motorcycle: cz 250 1932
:-D Did not have to re route anything on mine,just loosen the brake line at the master cyl and swing it down for a little extra length :wink:
On the road to anywhere
rodsprint is offline   Reply With Quote
Old 10-23-2006   #9 (permalink)
cagarrett
I had a post on here before the servers went down concerning the '07 Triumph risers for '05 and '06 models. I checked with my local dealer in Indianapolis and he quoted me a price of $199.00 for the kit and said it would come with everything needed to install, including cables. He used my vin number as there were 2 different kits.
He said the warehouse in Georgia did not show any in stock so it may take some time to get. I will let everyone know when I have them installed.
Old 10-24-2006   #10 (permalink)
Got to be careful the front brake line dose not pull tight and stress the crimped end when lifting the bike onto the centre stand as the front forks become fully extended. When I fitted my set of lifters this gave me concern and I had a goodridge made up, that was 25mm longer than standard, as a safe gaurd. Did not fancy sqeezing the brake one day and popping the pipe out of the crimped union.
StevyR is offline   Reply With Quote
Rivco Risers fitting issue vegasclive The Rocket Science Forum 2 10-08-2006 09:29 PM
Handlebar risers robbierob The Rocket Science Forum 2 01-01-2006 12:41 AM
Handlebar risers on UJMrider Hinckley Classic Triples 2 08-26-2005 12:52 PM
Handlebar risers, 05 ST b50bsa Sprint Forum 7 07-02-2005 07:21 PM
Handlebar risers smartin108 Tiger Chat 1 03-03-2005 09:51 PM
