Thanks Steve The dealer checked the compression after cleaning the stepper motor failed to fix it, He found No1@40psi No2@180psi & No3@60psi That explains the hard start and rough idle until it gets to running temperature then runs great. The dealer fitted the smallest shims available therefor next time it will need new valves, funny thing it didn't need shimming at 20k (or did it )
If at first you don\'t succeed ! Distroy any evidence you ever tried in the first place
