I ride a 2000 Sprint ST with 14K miles on it now. I took it into the shop the other day and they replaced my front fork seals, fork oil and adjusted the valves.
I spoke to the mechanic for a while and he had noted some points of interest that I should take care of sooner than later; those being Air Filter and Rear Brake Pads.
I've been poking around on the web and I'm pretty sure I'm going to go with a K&N filter (don't want to start any arguments here). I don't want to start a war on how they let more junk into the engine or that my tune will be all out of whack (tune I can handle with the tuneboy).
I know the PN is TB-9097 for my bike. Unless someone has a vastly superior solution they want to offer?
So the main issue is brake pads. I don't want to get factory, over-priced ones, so what are the other better options? I have been poking around on the web a bit and a lot of places have the RS listed for rears but not the ST, are they the same? If you have brand and part # I'd appreciate it, or if you know a place where I can order everything in one fowl swoop, that'd be much appreciated.
Thanks,
Jonathan
