Adjusting Steering Head - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario Tourism
Old 09-20-2006, 12:02 PM   #1 (permalink)
I'm going to adjust my steering head sometime in the next couple days and grease the bearing. The service manual says to torque the adjuster to 32nm as part of the process. In reading up on this on several threads nobody seems to be doing the torque business and just using anything from some kind of bicycle wrench to vice grips. Do you need to get some kind of special deep or thin walled socket to do this job and does anyone know the right size? I think it may be 36mm but ??????
Universal Laws of MC Forums
1. Just because the engine is on and the wheels are turning doesn't mean you're "riding".
2. The bike you ride and the farkles you buy have no correlation to how good a rider you are.
3. The ignorant can be enlightened, but the stupid just drive on forever.
rodneybrown is offline   Reply With Quote
Old 09-20-2006, 04:05 PM   #2 (permalink)
Favourite Bike: 2002 RS
Stlakid's Avatar
Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
From many, many posts on another website most of the steering head bearing failures were at the hands of the Triumph Factory, or a trained mechanic doing a scheduled service, so I wouldn't adjust it tho the factory specification.
The problem is the top bearing is used in an improper loading situation. A standard ball bearing is NOT designed for much side loading at all. When you adjust the races the top bearing is being side loaded in the Triumph setup. It is a standard radial ball bearing and not designed for this type of load. The lower bearing is a tapered roller bearing and is the one that does (and should) take the majority of the loads in their setup. The top bearing should only keep things centered and not be placed under much load (torque setting) at all.
Here's how I do them and I still have the original bearings in mine after 25k. Some people have gone through three or more sets during that time and were replaced by the dealer under warranty claims.
1. Get the front wheel off the ground. (An inch or two is fine) This way you can get some room to grease the lower tapered bearing which is not a sealed bearing. (it will be pretty dry!)
2. Remove the top triple tree. (Do not re-tighten the pinch bolts until all the adjustments have been finished). This will allow the wheel assembly to drop and give you access to grease the lower bearing.
3. Take out the top bearing (it's sealed) and make sure it doesn't have any rough spots. If it does replace it. They're only about $3.00! (unless you go to the dealer!) Part #6205-2RS
4. When you put it all back together only tighten the adjusting nut as much as you can WITH THE SOCKET HELD IN YOUR HAND! Do not use any tools here, just the bare socket and hand tighten it!
5. Rotate the handle bars back and forth to distribute the grease you applied to the lower bearing.
6. Loosen the adjusting nut and repeat step #4.
7. Be sure the assembly does not tighten (adjusting nut turns) when you tighten the top nut. Your done! And you're top bearing will not die because it was side loaded excessively. Don't forget to tighten the pinch bolts on the top triple tree now.
Now, there are a couple of fixes for this as well. They both require the replacement of the top bearing which is being used incorrectly unless it is not put under any side load, which is virtually impossible.
Replace the top bearing with an ANNULAR CONTACT bearing which is designed for radial as well as side loading. They can be had for about $12.00 and are a complete drop in replacement. Part #7205 Annular contact bearings.
Or replace the top bearing with another tapered roller bearing. These are also a drop in replacement except they are just under 1/16" to wide which really shouldn't bother anything. The top triple tree needs to be removed anyway and readjusted for bearing replacement or if you're just doing a bearing check. Part #30205 Tapered roller bearing. About $10.00 each.
The tapered roller bearing will take more side loading, but the Annular will be more than enough here. Either one will be fine.
Stock Replacement Bearing
Annular Contact Bearing
Tapered Roller Bearing
A little tip I used in using these bearings in not so clean environments such as this sense both the Annular and Tapered bearings are not sealed. Find an 'O' ring that will just lay around the inner race and cover the area where the rollers and grease would get dirt in them. Get the 'O' ring thick enough to just be compressed slightly when assembled in the assembly. This will keep out 95% of the dirt and keep the grease in the bearing as well.
[ This message was edited by: Stlakid on 2006-10-10 03:21 ]
My Photo Album
Stlakid is offline   Reply With Quote
Old 09-20-2006, 05:52 PM   #3 (permalink)
Thanks for the response Stlakid, it will be useful as I need to adjust and/or replace mine sometime soon
stevesrs is offline   Reply With Quote
Old 09-20-2006, 07:39 PM   #4 (permalink)
Outstanding description. Thanks.
Old 09-20-2006, 07:59 PM   #5 (permalink)
Favourite Bike: '03 Sprint RS
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Extra Motorcycle: CB400SF, 4 x DT175, MX80
Excellent info Skatlid. Thanks,
That's what I really enjoy about this site. The sharing of info - freely with the experience to back it up.
Great job :gpst:
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 09-21-2006, 02:48 AM   #6 (permalink)
Stlakid's Avatar
Just drug out the service manual and found an interesting section. The above adjusting technique was my own which I know to work and not damage the top bearing. This is the Triumph adjustment technique word for word.....
ADJUSTMENT
1. Raise and support the front of the motorcycle.
2. Slacken the pinch bolts ON THE TOP YOKE ONLY.
3. Slacken the headstock top nut.
4. Slacken the handlebar clamp screws.
5. Adjust the bearing free-play as folows....
A. Tighten the adjuster nut to 32Nm.
B. Loosen the nut and then re-tighten by hand until any bearing
free play is eliminated.
NOTE:
Correct adjustment is attained when the bearing play is eliminated without preloading the bearings.
It also recommends using Anti-Seize compound on the threads.
It seems that people (including the service department) would stop reading at the point of "Tighten the adjusting nut to 32Nm" It would seem that the torque setting is used to 'Set' the bearings only before actual adjustment by hand.
My Photo Album
Old 09-21-2006, 06:28 AM   #7 (permalink)
I read that section prior to initiating this thread and I read it exactly as you explain, but the way it is printed it is very confusing. I actually read it several times and compared it to a bunch of threads on several lists. The additional info did kinda sorta clarify it but the STlakid post is the only thing that flat nails it. Again, great post.
Old 09-21-2006, 08:02 AM   #8 (permalink)
Favourite Bike: 2002 Sprint ST
Extra Motorcycle: 1979 Moto Morini 3 1/2 in
Nice job Stlakid. Thanks,
Don
Old 09-21-2006, 08:05 AM   #9 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
You still da man kid!
Davem
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 09-24-2006, 05:10 PM   #10 (permalink)
Hey STLAkid,
HELP!!!!
I have tried to remove the top of the tripple tree and it isn't cooperating. The forks are completely out. The top nut is off but it isn't coming out so I can get at the adjuster nut. Am I missing something????
Help please - Steering head bearing gavinb Sprint Forum 8 11-25-2006 04:23 PM
steering head bearings firsttriumph Sprint Forum 3 07-15-2006 08:29 PM
Steering-head Bearings TBSstunta Hinckley Classic Triples 1 05-23-2006 09:47 AM
STEERING HEAD BEARINGS blacktiger Tiger Chat 2 10-03-2005 05:20 AM
Steering head SilverS3 Speed Triple Forum 3 08-30-2005 09:28 PM
