Running Lights & Dual Contact Sockets? - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsSportbikeTrackGearOntario TourismMotorcycle.comMotorcycle.com Classifieds!
Old 09-19-2006, 06:24 PM   #1 (permalink)
Does anybody know how to turn the front indicator lights only into running lights on the ’06 ST?? I would buy the Kisan SignalMinder module and use its running light feature but it is illegal to have rear amber running lights in California.
I know that I will need dual-contact bulb sockets………..but that is where my knowledge stops!!
Thanks as usual - BB
BlackBeauty is offline   Reply With Quote
Old 10-02-2006, 01:55 PM   #2 (permalink)
Favourite Bike: Triumph Sprint 955 (03)
Other Motorcycle: Can Am Spyder (08)
I've installed Run-N-Lites on several BMW's and was always annoyed that I had spent 30 bucks to get a few dollars worth of hardware. Anyway, they only supply kits for BMW's.
http://run-n-lites.com/run-n-lites/A...un-n-lites.asp
I recently bought an '03 ST and will be looking to do the same with the front and possible the rear signals. This is not very difficult - finding a dual circuit bulb socket and then wiring the running light contact to a switched feed circuit.
I will investigate the details and post my findings......
Stuart
Stuart_O is offline   Reply With Quote
Old 10-02-2006, 02:17 PM   #3 (permalink)
Hey BlackBeauty,
Do you know if they really enforce that amber law? I replaced my rear turn signals with dual filament bulbs using one filament as a turn signal and the other as a running light. The lens is amber, so I asked several retired PA state police about it. They said they would never waste their time over that. I did the same on a Connie prior to my current ST and have been running from GA to PA and all states in between without any problems.
Rod
Universal Laws of MC Forums
1. Just because the engine is on and the wheels are turning doesn't mean you're "riding".
2. The bike you ride and the farkles you buy have no correlation to how good a rider you are.
3. The ignorant can be enlightened, but the stupid just drive on forever.
rodneybrown is offline   Reply With Quote
Old 10-02-2006, 02:40 PM   #4 (permalink)
Hi - thank you very much for the responses. I actually these ereally neat, little units that allow you to alter the front lights independently - link is below. They turn the indicators on all the tie mand interrupt the current when you want to indicate. I have an appt. at the dealer to get them wired in - there is NO way I am atempting it!!
I do not know whether they enforce the amber light law - but it would be one less thing if somebody felt like pulling me over. I like to thini I am law-abiding with common sense thrown in - e.g., I always try and ride a little faster than the main flow and although this i speeding, I believe it puts me in a safer position on the road. I doubt it would be enforced - there are so many other blatant things that aren't. I'm probably paranoid!!
Thanks again - BB
Magic blinkers
Old 10-02-2006, 08:29 PM   #5 (permalink)
Those look cool. let us know how they install and work.
2ndSpace is offline   Reply With Quote
Old 11-25-2006, 04:03 PM   #6 (permalink)
Update: I had my local shop install them and a few hours later, they do exactly as it says on the box.
I'm very happy with them and they seem a very neat solution to what I wanted. I think the running lights up high are good for added visibility.
The indicators do flash more quickly now - they would need a different load relay. But I think they are fine as they are and do not plan to "correct" the flash rate.
Anyway - just wanted to let you know that they worked.
BB
Old 08-11-2009, 07:54 AM   #7 (permalink)
Jedi's Avatar
Neat product, glad they worked BB.
I think (not sure) but in Texas, the rear running lites HAVE to be red if they are on all the time.
Anyone changed thier rear lites out? Did you change the housing, or, just the lens? Is there a red lens for the Sprint?
Thanks!
Do or do not, there is no TRY...
-Master Yoda
Jedi is offline   Reply With Quote
Old 08-11-2009, 11:08 AM   #8 (permalink)
Favourite Bike: Sprint ST1050ABS -09
There is small T15 glasbase bulb so it is not easy to find so small dual filament bulb and base. (Base is similar than T10)
I have clear lenses and 36xled bulbs so maybe i modify those so that couple of those leds work as running lights...
AimoPaukku is offline   Reply With Quote
Running lights FattRat Twins Technical Talk 15 08-22-2008 06:51 PM
Running Lights Dig50 Sprint Forum 4 06-28-2007 01:20 PM
Running Lights? kballowe Twins Talk 3 04-03-2006 10:05 PM
Running lights IamNeighbordave Hinckley Classic Triples 4 02-18-2006 11:47 PM
Running Lights Yuddy Trophy 2 12-30-2004 12:34 PM
