To install the back rack you will need a socket to take the four bolts off to remove the rear rack. You will also need a flat blade screwdriver, preferably large blade. I believe you will also need allen wrenches and something to pry out or unscrew the plastic caps in the factory grab bar. I would recommend you take a craftsman, husky, etc socket kit with allen wrenches and a couple of screw drivers (flat blade) and some small pliers or vice grips for the plastic caps. This should do you well. Sorry I cannot give you specific sizes.
