Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.com
BikeBandit
Old 07-11-2004   #1 (permalink)
Just back from a 200 mile ride with a couple of observations:
Boy do I need a throttlemeister!! I had a Vista Cruise on my last bike, and it spoiled me.
My bike, now with 350-ish miles on her, seems to idle rough when warm. It idles fine first thing in the morning, or after a complete cool down, and runs fantastic on the road, great throttle response, mileage, etc. However, I noticed after a stop for gas and another to stretch my legs, that when I restart after a brief stop, it idles rough. It doesn't die, and takes off from idle just fine.
Additionally, when I come to a stop with the bike running (e.g., a stop light/sign), it idles smooth as butta. If I shut it off and then restart, however, again, rough idle.
A riding buddy suggested that the ECU is still "adjusting" - any thoughts?
Ken
OlyKen is offline   Reply With Quote
Old 07-11-2004   #2 (permalink)
I haven't had any problems with my Sprint having a rough idle. However, on your note about a throttlmeister, something I have that I think really helps on a long ride is a Throttle Rocker. I find it really helps.
Tom
'01 Sprint ST (red, faster and fun)
thfwsf is offline   Reply With Quote
Old 07-11-2004   #3 (permalink)
Do you turn the bike off with the key? Supposedly that lets the ECU do a normal shutdown, including remembering it's current settings. I've read that if you abruptly kill the engine using the kill switch and/or putting the sidestand down with the engine in gear, that the ECU needs to re-learn the idle settings. Or something like that... I always use the key and don't have any issues.
Pittsburgh RAT Pack
www.pghratpack.com
garry is offline   Reply With Quote
Old 07-11-2004   #4 (permalink)
Ken, make sure that the throttle is COMPLETELY CLOSED when you start it, if its cracked open any at all it sends a wrong signal to the ECU which tries to readjust the idle, making it too low which will cause it to idle very rough and/or stall.
Old 07-12-2004   #5 (permalink)
Favorite Bike: 2003 Sprint ST
The ECU will continue to adjust itself...
Just make sure, as mentioned before, that you start without opening the throttle... the ECU hates it.
SpiderTex is offline   Reply With Quote
rough idle jonno1953 Twins Technical Talk 10 11-14-2007 02:56 PM
Rough Idle - 1050 ST ABS brumey Sprint Forum 2 11-06-2007 12:08 AM
Rough idle htown16 Classic, Vintage & Veteran 7 07-25-2006 08:46 PM
overheating, rough idle....need some help SilverThief Modifications & Workshop Talk 8 04-22-2006 11:40 AM
'01 Sprint RS rough idle Sprint Forum 1 06-03-2004 10:00 PM
