Old 07-10-2004   #1 (permalink)
ChemProf
I was wondering about the power outlet on the side of my sprint. Looks like a possible way to run electric gloves etc. or a radio. What type of adapter do I need and where can I buy one. The outlet looks like it will take a thin cigarette lighter plug. The bike is a dealer demo I bought off the floor and the dealer isn't much help. Thanks in advance.
Old 07-10-2004   #2 (permalink)
Hi Chemprof,
Believe it or not you can buy one from a BMW dealer for about $40, or you can buy one from a John Deere dealer for about $10.
Preachp
Cruisin\' the byways of life for Christ
preachp is offline   Reply With Quote
Old 07-10-2004   #3 (permalink)
Preachp is right about the plugs being the same as the ones that BMWs and John Deeres use. There's a better source for these plugs than either BMW or JD. Check out the Powerlet plugs at the Jastek Engineerig website:
Jastek Engineering - Powerlet Plugs Clicky
I've ordered a couple of Powerlet plugs. The service is great and the plugs are high quality.
MikeWS1 is offline   Reply With Quote
Old 07-11-2004   #4 (permalink)
I've had the same question for a while. I took a look at the jastek engineering page and it looks like you have to do your own wiring for anything that you want to plug in.
Since most of the things I want to power have regular cigarette adapter plugs on them, don't' they just make a power outlet to cigarette adapter or would I need to rewire my cigarette adapter chord with this new end?
Thanks!
My Photo Album
vgermani is offline   Reply With Quote
Old 07-11-2004   #5 (permalink)
Favorite Bike: 2002 Sprint ST, BRG
Gatorman's Avatar
Other Motorcycle: 1978 Bonneville T140E
Extra Motorcycle: 2007 Suzuki DR 650
The BMW adaptor has a standard 12V cigarette lighter/power plug receptacle. Mine was ~$25 from the dealer. The John Deere version may be the same, but I couldn't find one locally.
Gatorman
"A sporting gentleman does not motor about at night" - J. Lucas
My Photo Album
Gatorman is offline   Reply With Quote
Old 07-11-2004   #6 (permalink)
On 2004-07-11 09:37, vgermani wrote:
... I want to power have regular cigarette adapter plugs on them, don't' they just make a power outlet to cigarette adapter or would I need to rewire my cigarette adapter chord with this new end?
Jastek Engineering sells cigarette plug adapters. See the link below. In most case you're better off changing to the BMW style plug. The Powerlet plugs are easy to wire.
Powerlet Cigarette Adapters clicky
Old 07-11-2004   #7 (permalink)
ChemProf
Thanks Preachp and MikeWS1. I think the stuff I see in the aerostich catalogue will work and the Jastek reference will be good for wiring up some onboard electronics. Now I need to find somebody who has installed a CB on the Sprint.
Old 07-12-2004   #8 (permalink)
seems like a silly question but can you use tha out let to charge the battery using a Battery Tender? :???:
Old 07-12-2004   #9 (permalink)
Yes, you can. Go to Jastek Products Page and find the battery tender adapter. I have one of these, works great.
fast... cheap... good... pick two.
frizbee_dog is offline   Reply With Quote
Old 07-12-2004   #10 (permalink)
I bought mine at the John Deere dealer. I think you can get the plug from a Case dealer as well. The outlet is alway hot. I put one of the plugs on the cable on my Battery Tender. It makes connect of the charger a snap.
Devo is offline   Reply With Quote
Power outlet Calzor_Suzay Sprint Forum 3 06-14-2007 09:41 AM
Triumph Power Outlet Towelie Sprint Forum 13 11-21-2006 08:09 PM
Power outlet plug tony2 Sprint Forum 2 07-04-2006 02:20 PM
Power Outlet for '03 Sprint ST cricket1 Sprint Forum 2 03-15-2006 03:14 PM
ST power outlet Sprint Forum 4 04-17-2004 12:46 AM
