BikeBandit
Old 09-03-2006   #1 (permalink)
Is there one or has anybody fitted one. Applogies if there is a previous post but I cann' find it.
Thanks
Kev
Why is there so much month left at the end of the money?
Thefallenone is offline   Reply With Quote
Old 09-03-2006   #2 (permalink)
Favorite Bike: 02 Sprint RS
rs_tt's Avatar
Other Motorcycle: 1983 Suzuki GS250FW
There isn't one, but you can get one at any auto supply store
and fit it just about any thats conveinent for you.
good luck
pieracer
rs_tt is offline   Reply With Quote
Old 09-04-2006   #3 (permalink)
Would something like this be suitable? I expect it would come with instructions.
Nippy Normans Car Socket
Old 09-04-2006   #4 (permalink)
There's an existing point to plug in an accessory outlet that corresponds to the one on the ST. All you have to do is purchase the outlet. The stock one's a little expensive, but Powerlet makes one, as does John Deere, that are the same, but cheaper. Sorry, I don't have the numbers for them. Best luck.
cyclebob is offline   Reply With Quote
Old 09-04-2006   #5 (permalink)
Where does it plug into the loom?
Kev
Old 09-05-2006   #6 (permalink)
Favorite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
There is a dangling 2 prong connector above the gearbox on the bottom of the injector loom. tis the factory connector for an accessory plug. It runs through a 10A fuse.
you can mount the powerlet anywhere you want. I put mine on the left side fairing, next to the heated grip switch.
I have enough money to last me the rest of my life, unless I buy something.
chefjpd is offline   Reply With Quote
Old 09-05-2006   #7 (permalink)
Nice one mate. Will look tomorrow. I hope I can buy the right connector from powerlet.
Kev
Old 09-08-2006   #8 (permalink)
Found the outlet socket and contacted powerlet. They said they do not have a connector, but I should source a triumph connetor and fit using spade connectors. Can I not buy a plug and play socket? This is what powerlet suggest fitting.
Old 09-08-2006   #9 (permalink)
chefjpd's Avatar
That's the plug I used.
As for the connector, I just picked up a weatherproof connector with pigtails from an electronics shop, and cut off the factory plug.
Old 09-08-2006   #10 (permalink)
Aaahhh I see said the blind man. I will look into a waterproof connector. Cheers.
Kev
Accessory socket 03SpdFour Sprint Forum 1 07-17-2006 01:02 PM
Accessory socket wiring Sean24 Trophy 3 03-04-2006 08:04 AM
Accessory socket colinwa Sprint Forum 5 12-27-2005 03:09 PM
Accessory socket jackn Tiger Chat 29 12-26-2005 09:53 PM
accessory socket Gazzer Speed Triple Forum 2 10-01-2004 09:51 PM
