Motorcycle.comBikeBandit
BikeBandit
Old 07-07-2004   #1 (permalink)
ChemProf
Temp gauge stopped working and I am getting occasional electrical spiking on my tach and speedometer. Any suggestions? Thanks in advance.null
Old 07-07-2004   #2 (permalink)
Favorite Bike: 2003 Sprint ST
Sounds like a loose wiring or something totally belly-up.
Check battery contacts, check plugs ECU end, check that all connectors are good connected and that the metal is not corroded
Bike still runs fine right?
SpiderTex is offline   Reply With Quote
Old 07-07-2004   #3 (permalink)
ChemProf
Yes, bike runs great. Every so often the tach and speedometer jump around. Thanks for the reply.
Old 07-07-2004   #4 (permalink)
Hi Chemprof,
Check the dash wiring. It sounds like a the power or ground source for the dash is loose, or there is a broken wire bouncing around and touching things it shouldn't.
Preachp
Cruisin\' the byways of life for Christ
preachp is offline   Reply With Quote
Old 07-09-2004   #5 (permalink)
ChemProf
You got it! Found loose connections under the cockpit. While moving the wires around even the temp gauge responded. Using the service manual I'll remove the fairings and cokpit fairing and attack the problem. Thanks for the help.
looking for temp gauge cap-10ken Speed Triple Forum 1 08-16-2007 08:25 PM
Temp Gauge CeeGee Speed Triple Forum 0 08-04-2007 03:42 PM
Temp Gauge granburysprint Sprint Forum 4 06-11-2007 01:58 PM
Temp gauge Caffeinated Twins Talk 16 04-23-2006 12:55 PM
temp gauge SDFOUR Triumph SuperSports 1 04-28-2004 09:19 PM
